Old 11-29-2010, 02:46 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
There are a few threads on replacing the starter. Here is a good example.
EDIT: Thread has been trimmed and moved to the MKIII FAQ. Hyperlink above is to the new location.
Old 11-29-2010, 07:55 PM   #2
mostdef
mostdef's Avatar
mostdef is on a distinguished road
ok, thank you very much. He said it overheated, but I am sure he put mineralized water in the system. Also there are some plugs on the right side of the engine bay towards the front by the battery? I assume these plugs are for some fans that I am missing? What fans are these I know they can't cost too much. It needs the starter then I am going to track down the rest of the problems from there. I traded an N/A running car for a non running turbo. It looks immaculate almost though. It has had the head redone with a copper reinforced gasket torqued to 75 or 80 ftlbs. The guy drove it till the starter had no life and now just wants a running car. I got a battery in it and it clicked and all the cluster works, so it shouldn't be too bad.
mostdef is offline   Reply With Quote
Old 11-30-2010, 02:40 PM   #3
Green7mgte
Supra Forum Moderator
wilson. clean that thread up and make it an faq man.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 11-30-2010, 03:15 PM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Good idea, done. Check it's new home in the MKIII Faq. It's been sticky'd
Tags
starter, supra, toyota, transmission, turbo
