As usual, check for codes (even if the CEL is off).
I'm thinking either faulty Idle Speed Control valve, possibly vacuum leak. Check the TSRM for testing procedure of the ISC, and listen around the engine bay for vacuum leaks with the engine running. I believe an out of adjustment TPS may also cause this issue, testing and alignment procedures are also in the TSRM.
Idle hunting issue | Durandal | MKIV Supra | 18 | 08-28-2010 09:05 AM |
Rough Idle Issue | suprajim | MKIII Supra | 9 | 12-19-2009 10:35 PM |
idle issue | MA70-3.0GT | MKIII Supra | 14 | 11-17-2009 05:01 PM |
Blow off valve / idle issue | AlpWhitE46 | MKIII Supra | 9 | 10-10-2008 11:49 PM |
Wastegate Idle issue... please help | Subjug4tor | MKIII Supra | 9 | 05-15-2008 01:59 AM |
