Old 09-13-2010, 04:02 AM   #1
Conga1991
Conga1991 is on a distinguished road
Default Car wont turn over after swap!
Alright so first thing is details. I just swapped a 7mgte into my 7mge supra. I have the same year ecu with harness and motor but my body is 88 which doesnt make a difference since pre 89 are the same. The harness was for a automatic and decided to use a R154 tranny. So I researched how to bypass the nuetral system and spliced the two wires off of one round plug together.
Things I havent done yet is put the Turbo tachometer in yet and thats the only thing. I used the original NA starter and figured I didnt need to change that out. I also got a 100 amp fuse for the alternator, is that the right one or is it a 80 amp? originally there was just a wire connecting to each side to get power to the alternator. There is two small plugs from the harness next to the ecu that dont have a place to pug into, one is black and the other is yellow. And I havent conneted 3 wires that go to the water neck, they are the ones that slide onto the metal like the fan shroud and coolant temp switch. Other then that everything is connected.
There is power because I replaced the battery the other day.
Any and all sugestions are welcome to what the problem might be?
Conga1991 is offline   Reply With Quote
Old 09-13-2010, 12:53 PM   #2
what happens when you turn the key??
plz explain...
because i pulled a 7m engine recantly and forgot some starter wires...
Old 09-13-2010, 06:23 PM   #3
Conga1991
When I turn the key to turn it over theres one click noise coming from where the ecu is, which was kind of strange and I couldnt pin point where exactly where it was coming from.
Also the fuel is going cuz I hear a spray and I have a little fuel leak which Ill fix as well as a small coolant leak on my floor.
Old 09-13-2010, 06:26 PM   #4
916MKIIIx2
916MKIIIx2 is on a distinguished road
you might want to unplug the fuel injection until the starter atleast starts kicking, so you don't flood the cylinders. Take a vantage or something to the starter wires and make sure you're getting power, you can do an amp test by cranking the started while having the leads in the proper position on the started case and on the big ass wire bolt attached to it, i think thats right atleast its been awhile.
916MKIIIx2 is offline   Reply With Quote
Old 09-13-2010, 07:02 PM   #5
Conga1991
okay. when you mean by unplugging the fuel injection you mean each wires to the injectors right?
Old 09-13-2010, 07:49 PM   #6
916MKIIIx2
EFI fuse should do it
Old 09-14-2010, 12:26 AM   #7
when i did the swap same clicking happened it was wierd.
A.starter was hooked up wrong
B.battery was dead (check that you have proper voltage.)
you need air fuel and spark.
your missing one...
Old 09-14-2010, 05:12 AM   #8
916MKIIIx2
FYI, you pull the EFI fuse so your car wont be spitting fuel into the cylinders while doing voltage and amps checks on the starter, pulling the EFI fuse will in no way hinder you from making sure your "starter" is working, go to google and type in starter AMP test, and starter voltage test to see what you need to do. "I AM IN NO WAY SAYING THE EFI FUSE IS BAD" Just pull it before you do cranking tests.
Old 09-14-2010, 04:55 PM   #9
depami
The alarm system can also disable the starter.
Denny
82 5 sp 928 - Guards Red
92 FlightCraft 18 XLT
94 1200 Sportster
01 F150
Old 10-04-2010, 04:07 PM   #10
t12tninja
t12tninja is on a distinguished road
i would say check your grounds cause i had the same issue but i didnt do a swap but it sounds like my problem check all the grounds and mine was the ground in the steering colum
t12tninja is offline   Reply With Quote
7mgte swap vs 1jz swap Supra Saiyan MKIII Supra 15 04-24-2012 02:58 AM
headlights wont turn off after swap 89supra884 MKIII Supra 7 04-19-2010 03:24 AM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
NA->T swap and convertion questions 5+4=9 MKIII Supra 6 03-02-2006 02:11 AM
