Old 08-31-2010, 02:05 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default overheating then no starter
So a few days ago I was on a back road up in the mountains and my car overheated. But it didn't just overheat, it overheated then bogged out and died. I went to try to start it and all I hear was a click. So I thought ok so I overheated my starter, then I waited half an hour and the same thing. So we roll started it and I drove it home. Haven't driven it since. So the starter just clicks now when I start it. Problem started when it overheated.
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 08-31-2010, 04:19 PM   #2
Ranma
Ranma's Avatar
Talking
My 89 Firebird started to do the same thing after a hard ride through the mountains. It refused to turn over at first but started after a cool down. The starter went tango uniform not long after. I can only suppose the excessive heat damaged the solenoid somehow. It worked in a cool condition but never warm. I can only supose the engine overheat vs hot engine has speedup up the process.
Old 09-06-2010, 08:29 AM   #3
supraluver4life
it dont work at all lol
+300rwhp
Old 09-06-2010, 01:22 PM   #4
Ranma
Ranma's Avatar
Talking
My lingered for years, was out of the country mostly but not long after returning full time it failed for good. I think the overheat damaged the starter somehow. You can take it out and test it or you can apply power directly. If it is ok, a relay must be bad. Have you checked the solenoid?
Old 09-06-2010, 04:26 PM   #5
supraluver4life
and how do i check the solenoid?
+300rwhp
Old 09-06-2010, 05:49 PM   #6
Your problem could be the starter/solenoid, could be old wiring, could be bad connections somewhere.... Pull the starter out, go bench test it at an auto parts store, and post back with the results. We can help you more once we start narrowing down the problem.
Old 09-06-2010, 09:01 PM   #7
Bill UK
AEM EMS
Bill UK's Avatar
Try this first; connect a wire (about 15 – 20 amp) to the small spade connector on the starter motor, there are only two wires going to the starter, (both are positive) one large red wire which is bolted on to the starter and one thin one that is connected to a plastic shielded spade connector, (this is where your new wire connects to). The other end of the wire temporally insulate for now, turn on the ignition (make sure its not in gear) remove the temporary insulation from the new wire and touch the positive terminal on the battery. If it does start and you continue to have success, let us know.
Old 09-06-2010, 10:10 PM   #8
speedfiend
speedfiend's Avatar
speedfiend is on a distinguished road
If you have the required voltages on the starter hot leads I would put a socket & ratchet on the harmonic balancer and make sure that the engine hasn't seized.
Driving one hot enough to shut down is a very bad thing, I have seen many in that condition that locked up tight, sad but true...
My 2 cents
88 N/A targa, 5 speed, tint, thumpin' tunes, APEXi & KYB's, tweaked AFM, Hayden fan...
5 Favorite yodas I've owned, I am a believer!
85 Supra 5 speed, tint, sunroof
77 Celica GT, 20R, 5 speed, tint, cam, header, tweaked Mikuni S/Ds, K&N
91 DX & 99 LE Camrys, for when I did the family thing
86 1 Ton P/U, 22RE, SR-5 speed, tint, buckets, 500w stereo, header, alloys, tweaked AFM, K&N
86 4x4, 22RE 5-speed, tint, 4" lift, cam, header, tweaked AFM, K&N, bored .040
500 character limit...
speedfiend is offline   Reply With Quote
Old 09-06-2010, 11:25 PM   #9
My 2 cents
I agree.... PLEASE make sure to pull the EFI fuse or, better yet, disconnect the battery first!!!!!!
Old 09-07-2010, 05:17 AM   #10
916MKIIIx2
something you're taught in auto school, unplug the negative battery and remove the fuel injection fuse/fuel pump, and hopefully that bad boy turns when you take the ratched to it ;;
Starter issues! Please help bryanf89 MKIII Supra 4 04-10-2010 05:43 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
starter removel? swied MKIII Supra 4 04-23-2007 04:50 AM
