Old 08-25-2010, 04:20 AM   #1
mkiiisupra
Default Battery relocation question
I purchased the power distribution block listed below and had a question about wiring it.
Can i use one of the three 4 gauge inputs as and output to the starter and the other as the input from the battery?
I do not want to limit the starter with a 80 amp AGU fuse ( using that for the power that goes to the fuse box )
Monster 200 AGU PowerFuse™ Fused Power Distribution Block (Three 4 Gauge Inputs/Four 8 Gauge Outputs)
http://www.monstercable.com/mpc/prod...14&section=two
1990 Toyota Supra Turbo A/T
Old 08-29-2010, 04:05 PM   #2
I can't imagine why you'd have any trouble with it. You'll probably want to run heavier from the battery to the front though. 0 AWG welding power cord is most commonly recommended.
Quick question prior to ordering parts Grandavi MKIII Supra 16 07-07-2010 05:17 AM
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
battery wont hold charge CanadianBak'inSupra MKII Supra 1 05-07-2010 05:12 PM
