Battery relocation question
I purchased the power distribution block listed below and had a question about wiring it.
Can i use one of the three 4 gauge inputs as and output to the starter and the other as the input from the battery? I do not want to limit the starter with a 80 amp AGU fuse ( using that for the power that goes to the fuse box ) Monster 200 AGU PowerFuse™ Fused Power Distribution Block (Three 4 Gauge Inputs/Four 8 Gauge Outputs) http://www.monstercable.com/mpc/prod...14§ion=two |
I can't imagine why you'd have any trouble with it. You'll probably want to run heavier from the battery to the front though. 0 AWG welding power cord is most commonly recommended.
| All times are GMT. The time now is 04:53 AM. |
