Old 08-14-2010, 05:58 PM   #1
afsvanderveen
afsvanderveen is on a distinguished road
Question 87 to 89 conversion
hey there, I bought a mint 89 turbo chassis and already had a 87 turbo car. The 87 was in rough shape but the engine is great. it been taken care of and the head has all been redone already. I want to put my gear in the 89 car. The 87 is atomatic and I am putting a 5 speed from another turbo car into the 89, which was originally a maual to begin with. So that wont be too bad. the guy I bought the 89 from cut the fuse box and a bunch of other components out and just cut the wirring for the gauge cluster and again other things out of the car. I was going to re wire the entire car with my 87 components. Basically start from scratch. Does anyone have experience or links or any advice to make this easier? There is a ton of wirring and its a daunting task. Is there anything thats the same between cars, ie body wirring, ect? I know the engine wirring is likely diffrent but thought I look for some help. Thanks a lot!!!!
afsvanderveen is offline   Reply With Quote
Old 08-14-2010, 06:25 PM   #2
as far as i know there should be little differences between the 2.
and really the wiring is strait forward, each plug onnly has one place to go and only 1 other plug will mate with it...
easier than you think.
Old 08-14-2010, 07:19 PM   #3
Quite different actually. Different engine harness, different dash harness and all of the lighting connectors are different but the wiring and internal clips are all the same IIRC.
Old 08-15-2010, 03:51 PM   #4
oh wow, didnt know.
but either way every clip can only go into its mate clip.
thanks for clearing that up!
Old 08-15-2010, 08:07 PM   #5
I'm not sure what you mean by this..
Old 08-16-2010, 02:13 AM   #6
afsvanderveen
i think he means every plug, as they all semm to be diffrent either by shape or colour with corresponding male and female ends. I think thats it, correct me if im wrong though. So im sure the wirring is quite diffrent now, i am tearing everything out of the 87 to put in the 89 chassis. What a job this will be. Any ideas on what may plug and play? Heater box? or any of that stuff? I was hopping some items may mesh between years but so far it doesnt look like it.
Thanks
Old 08-16-2010, 02:56 AM   #7
obviously a triangle cant fit into a square...
Old 08-16-2010, 11:57 PM   #8
afsvanderveen
ok i get that,duh lol. I was looking at the tail light connecters and I can plug my 89 light in to the 87 harness. Do they work fine like that or do the pins feed power diffrently between years? Its a ton of work to pull all the wirring and change them over, maybe ill just have to go out to where the 89 is parked and start looking around. Thought maybe someone had more experience, in this area. thanks again though.its starting to rack my brain a bit
Old 08-17-2010, 12:57 AM   #9
if your tail lights plug in fine check your fuses in both cars, should be the same, so i imagine they would be fine.
its a massive harness its pretty funny
Old 08-17-2010, 01:09 AM   #10
Front signals have a different lamp holder... either cut the old one off and crimp/solder on one of the right year or file off the bits that get in the way.
92 Supra HID conversion kits. Green7mgte MKIII Supra 3 12-12-2009 07:39 PM
JDM dash conversion kit???? Wellerd99 Exterior , Interior, and Detailing 1 07-14-2009 03:19 AM
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
7MGTE-7MGTEU conversion guide? ravenmaster MKIII Supra 1 02-17-2008 01:17 AM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
