Old 08-12-2010, 02:50 AM   #1
supraluver4life
supraluver4life is on a distinguished road
Default More power less stuff ???
so im currently building a mostly stock 7mgte. Im shooting for around 350-400 horses. One of my big pet peeves with the supra is all the electrical humbo jumbo. Basically what i would like to do is make my own wiring harness and strip down as many things off the car as is possible. All i want under the hood is an engine, none of the electronic BS that came ion the supras. if someone could chime in with any threads about maybe EGR removal or such things that would be great. And i would really like to know what must stay. i really want to simplify this car and not have to worry about elecricalo problems ever again. Oh and can i use the stock ECU with everything missing? And no i dont car about check engine lights at all!!!!
thanks
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 08-12-2010, 03:00 AM   #2
MJG
MJG's Avatar
Have you considered selling the Supra and buying a "57" Chevy?
Old 08-12-2010, 03:07 AM   #3
supraluver4life
More like a 240sx s13 haha. But i love my poopra too much. Ive seen builds done with simplification but im not sure how to approach it. I have a spare wiring harness that im essentially going to tear apart and refine, simplify, and make more discrete (harness tuck).
+300rwhp
Old 08-12-2010, 03:33 AM   #4
Plenty of electrical in the 240 last I worked on one.
You're not going to be able to use the stock ecu at all actually. Do remove all the electrical you've have to convert to a distributor with vacuum advance and ditch the fuel injection in favor of a carb... The ECU's programming is too dynamic, too tailored for every subtle change for you to start deleting sensors left and right (besides, you could only pull half of it unless you really convert to a carb and dizzy)... that's the entire point, wring out as much power as possible under as many conditions as possible.
Old 08-12-2010, 03:45 AM   #5
supraluver4life
so to keep the efi, distributor-less spark, and keep electronic tuning capabilities, what can i remove? What sensors? Can someone point me to an EGR removal write up? because i cant find one for the life of me. Maybe i exaggerated a little about how simple i want it. I would just like it to look a little more refined under the hood.
+300rwhp
Old 08-12-2010, 03:49 AM   #6
You may delete the A/C and it's wiring and aux fan and you may delete the TEMS system and the power steering... if you want to keep your power you'd best leave the EFI system alone.
Leave the EGR, it reduces combustion chamber temps and costs the 7M no power. Otherwise you'll also need to source a JDM ECU and deal with the fact that it's got a governor on it.
Leave the charcoal canister, that one you can replace with a much smaller one from a Tercel and tuck it inside the fender.
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
only starts by jump start ItsnotmySupra MKII Supra 6 04-27-2008 03:14 AM
Before buying an 85 P Supra with 123k what to look for e30cabrio MKII Supra 0 02-24-2008 08:09 PM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
