Old 08-12-2010, 04:44 AM   #1
Actually, as you've already got both on hand it'll be plenty evident when you start swapping parts. If you're keeping the A/T ECU you'll want to route the neutral start switch through the clutch switch. Then you'll need to swap transmission, clutch master cylinder and lines, brake and clutch pedals, clutch switches (one acts as the NSW and the other prevents the cruise control from over-revving the engine when the clutch is pressed), drive shaft.... there's more but it's just little things.
Speed Sensor Problem (Auto) GettaRobo MKIII Supra 8 04-26-2010 12:27 PM
New to MK4 (Auto TT to 5-or 6 Speed TT?) Mattz32 MKIV Supra 2 11-01-2008 06:25 PM
5 speed harness on auto? go.stfu MKIII Supra 2 10-09-2007 01:57 AM
Auto or 6 speed??? 2JZEFINI-17 MKIV Supra 13 09-11-2006 11:19 AM
