Old 08-05-2010, 02:52 PM   #1
Mike87
Mike87 is on a distinguished road
Default Gas tank leaking on turns but not when parked
87 turbo, set up 3 years. had tank cleaned out and fit back. all seemed good. drove back from FL to SC last week. On the way back, though, filled up tank for first time. I was expecting the gas pump to just automatically shut off or even come out the top but instead when full i see this gush come from the bottom of the car. It does not leak when parked. It seems to leak when accelerating away or pulling in my driveway, turning etc., which makes me think it is something toward the top of the tank or coming down from filler. Any ideas? Thanks!
Mike87 is offline   Reply With Quote
Old 08-05-2010, 03:39 PM   #2
Green7mgte
Supra Forum Moderator
if it leaks when your filling it maybe the neck.. (filler) has corroded? happened on a work van. everytime i would put gass in it it would leak all over the pavement at the fill station..
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-05-2010, 05:05 PM   #3
Mike87
yes, that is what I was thinking too. Can you get a neck separate or is it all one piece?
Old 08-05-2010, 08:44 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
Lots of individual parts, Link , you will need to drop the fuel tank .Not the easiest of jobs, you’ll find every thing that needs to be undone is rusted solid or falling apart. (especial the tank straps) not the place to use a blowtorch to loosen things up either, spray what you can with penetrating fluid and leave for a few days before you start.
PS: Listed numbers shown in the diagram are just figure #`s and may not be Toyota stock part #`s
Old 08-05-2010, 11:53 PM   #5
Green7mgte
this a turbo or NA..
if its turbo I would suggest that whilst you have your fuel tank dropped upgrade your fuel pump to a walbro 255.
if its an na.. than get a turbo. lol. jk, not really.
Supra FAQ
Supra MKIII FAQ
Old 08-06-2010, 12:47 AM   #6
I think I might have a poor seal between tank and filler neck on the '2'..... gonna be interesting pulling that tank out...
Coolant overflow tank relocation? MJG MKIII Supra 0 05-14-2010 04:07 AM
Slow Bubbles Into The Resevoir Tank Drag0na5h MKIII Supra 2 03-18-2008 05:37 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
Oil Is Leaking I Have Pics!! Need Help!! Ahmad88 Non-Generation Specific Questions 18 07-09-2006 03:56 PM
