Old 07-31-2010, 01:03 AM   #1
MyfirstCar
MyfirstCar's Avatar
MyfirstCar is on a distinguished road
Default window problems
so i jus bought a toyota supra and the power windows dont work for the passenger side and the drivers side wont go up jus down. any suggestions on what i should do.
MyfirstCar is offline   Reply With Quote
Old 07-31-2010, 06:20 AM   #2
bills1988
bills1988 is on a distinguished road
Default Window issue
The online TSRM is your friend:
http://www.cygnusx1.net/Supra/Librar...aspx?S=BE&P=49
Also, suggest you check the FAQ and/or do a search on your problem.
1988 MK3 Supra; 7M-GE; Automatic; Sport Roof; Factory Original
bills1988 is offline   Reply With Quote
Old 08-01-2010, 05:28 PM   #3
The power for the passenger side switch comes from the driver's side master switch (it's how the passenger window lockout, the square button, works). It's most likely that your switches are too corroded internally for any solid electrical connection to me made... pretty common and I'd start with that first. If you think you can tear it apart and clean it up yourself, go for it, you only need patience, a philip screwdriver, a small jeweler's screwdriver and some very fine sand paper. If you're uncomfortable with the prospect, pay someone who has done it to do it for ya.
Other possibilities would be the window control relays (one module in the drive's side door) or faulty wiring.
Need Help Finding Window 87TT MKIII Supra 13 03-22-2010 04:52 AM
Passenger Power Window Problems JanusDuo Non-Generation Specific Questions 1 12-17-2008 08:11 PM
