#1 | |
#2 |
when in doubt...
CHECK FOR ERROR CODES! http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=23 follow the instructions.
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#3 | |
but thos instructions help thanks i should be doing this tomrrow thanks
#4 |
lol at least bulbs are cheap. and its about time, because you should always have operational engine lights
#5 |
Bone Stock w Upgrades ;-)
Is the parking brake released? Will the car roll from a stop on a slight hill? Jack up each wheel and try to turn them. The back will be harder in neutral. Checking for a seized caliper or parking brake.
#6 |
#7 |
Supra Forum Moderator
did you check the engine codes?
92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#8 | |
i had a caliper seize on me last year and it was only because my system needed to be bled, even still i could drive it while it was seized just after 5 mins of driving it would heat up the brake system and totally stop all movement of the car...
#9 |
![]() Toyota Racing Development Join Date: Apr 2007
A bad knock signal to the ECU (bad knock sensor or bad wiring) will cause the ECU to operate in what is commonly referred to as "limp mode"... if the faulty signal is interpreted to be beyond a certain threshold... otherwise, the ECU may just pull timing and add fuel causing poor mileage and lack of power but not to a crippling degree.
Fix the knock sensor... it's a MAJOR problem. If you have issues after that post up the details. Oh, and replace the damned check engine bulb; You're wasting everyone's timing otherwise. The answer could have been right there in front of you (could still be if you have any other issues on top of the broken knock sensor).
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#10 |
i beleave i found the problem! but im not 100% sure..my knock sensor is broken and need to buy a new one could this be the problem?
| Thread | Thread Starter | Forum | Replies | Last Post |
| jdm 7mgte more power than usdm gte????????? | jdmmilhouse | MKIII Supra | 21 | 07-13-2010 03:16 AM |
| no spark | chrism8799 | MKII Supra | 6 | 12-08-2008 12:38 AM |
| Ghetto is a good seller | ARZ | Buyer/Seller ratings | 0 | 11-15-2006 11:58 PM |
