Old 07-01-2010, 05:32 AM   #1
abeale27
abeale27 is on a distinguished road
Default turbo charging a 7mge
i bought a 1989 n/a that id like to turbocharge. HELP!
abeale27 is offline   Reply With Quote
Old 07-02-2010, 12:40 AM   #2
mirage83
My 2 cents, don't try. Find a GTE engine in good shape if you must, but turbo'ing a N/A is generally more trouble than it's worth.
Old 07-02-2010, 02:31 AM   #3
907mge
907mge's Avatar
Even if you were to turbo a 7mge, it would be wise to rebuild it first. So why go to the trouble of messing with the non turbo and just buy a 7mgte . The 7mgte in many ways is built better for a turbo already.
Old 07-02-2010, 02:51 AM   #4
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
The only difference in the block with the NA vs turbo is that the turbo has oil squirters. However the GE electronics might be a pain to work with when going turbo. I think CRE had a setup like above. Anyway, i think its better to go with a 7mgte swap and save all the hassle.
91ma70 is offline   Reply With Quote
Old 07-02-2010, 05:02 PM   #5
CRE also blew a hole in a piston at lower boost than a GTE would take due to the GE's higher compression. If you do go N/A-T, at the very least add a thicker HG. The GE electronics aren't as good of a starting point as the GTE.. you'll be playing catchup and spending money on components you could have otherwise spent on upgrades.
Save up and swap in a GTE.
Old 07-03-2010, 12:01 AM   #6
wstanek
wstanek's Avatar
wstanek is on a distinguished road
these guys did it look... =D ima do it watch me...
http://www.youtube.com/watch?v=pI48ybtEAb8
wstanek is offline   Reply With Quote
Old 07-11-2010, 05:20 PM   #7
abeale27
yeah i had the engine rebuilt already and its gonna be at least 2 grand to turbo it myself. im thinking if i find some parts at a scrapyard that are in decent shape ill save some cash but swapping seems like a great idea. thanks a lot y'all!
Old 07-12-2010, 06:41 AM   #8
Grandavi
Grandavi's Avatar
http://4cefed.com/conversion.html
The above link lists parts, etc.. to do it. Dont know how accurate it is, but it makes good reading.
turbo charging suprabahamut MKIII Supra 0 02-19-2008 01:07 AM
How far can you push a 7MGE on turbo? Turbotuner2.3 MKIII Supra 6 10-26-2007 09:12 PM
