Old 09-02-2005, 08:52 PM   #1
Prez420
Prez420 is on a distinguished road
Default front air spoiler/scoop
I just bought a 1987 coupe Turbo. on my way home (14 hours of travel) I managed to rip the front air spoiler off. I guess that can happen at 245km/h
Im wondering where I could buy one of these (possibly in Canada)?
I dont want to drive without it. Im sure it traps air in to keep the car running cool.
any help would be great.
what a find though... 1987 coupe turbo. 73000 kms ORIGINAL! with a K&N air filter and a 3" stainless cat back. everything else is stock. ALL the options. $8500 Canadian.... so whats that in US funds??? $100? lol
Prez420 is offline   Reply With Quote
Old 09-03-2005, 09:30 PM   #2
mrnickleye
mrnickleye's Avatar
If you are talking about the 2-3" black plastic air dam that bolts onto the bottom of the bumper in front, I took mine off. Most people take them off.
It won't make much difference in cooling. But what 'will' make a difference is if your missing the engine bay 'undershield'.
You at least need the very front part, like mine.
I made one from galvanized sheet metal that goes from the front of bumper to the frame that's directly under the radiator. I used existing threaded holes with 6mm bolts. That way air coming into the lower grill is 'forced' to go thru the radiator, and not just under it, and the car.
Old 09-04-2005, 08:14 AM   #3
Prez420
it was more like 2-3' (feet) square in size. it bolts on in about 5 or 6 spots under the engine. I did take mine off completely. I really couldnt tell you what it looks exactly like. I lost a bunch of it at high speed.
Old 09-04-2005, 06:48 PM   #4
mrnickleye
mrnickleye's Avatar
2-3 ft sq ??? are you talking about the piece that covers the bottom of the engine bay ??? the splash shield. , or are you meaning a piece that would be like
3-4" high x 2-3' across, bolted onto the bottom with approx 5 bolts, and projects down, to divert air and create a vacuum on the back side to draw more air thru the radiator. Many other types of cars have this piece.
Old 09-05-2005, 10:54 AM   #5
Prez420
im thinking its the splash shield
Old 09-06-2005, 05:31 AM   #6
rnoswal
rnoswal's Avatar
It probably is the splash shield under the car. It may have already been broken in half. On mine it is a long, one piece of plastic that bolts on under the car, from the front air dam to just under the engine crank pulley. Maybe some of the others came in two pieces. I also built a sheet metal shroud for the part that goes from the air dam to just under the radiator. It is needed I think for cooling purposes. It also catches tools and nuts and bolts while working on the car....;-).
Russ
Old 09-06-2005, 06:36 AM   #7
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yea not many ppl have these on any more
i don't have a fan shroud or engine undercover... or any of that lol
while my hg was good i never had any cooling problems stayed 185deg in traffic and city areas all the time, highway i dropped to bout 180
but then our temps are slightly different over here... not roasting weather
Pics of my build.
Do a diagnostic first!
Old 09-06-2005, 03:43 PM   #8
rnoswal
rnoswal's Avatar
Just curious on what the temps are there in NZ? Summertime here in Louisiana around 95 to 100 for three months. Makes you want to move right on over here doesn't it! I can't wait until our psuedo fall/winter gets here to see if I can turn off the cooling fan, just as a test of course. Roll the windows down, doesn't seem to rain here much either. Nothing sounds as good as a straight six with a good exhaust system, revving up through the gears.
Have you seen Bilbo yet?..;-}
Russ
Old 09-06-2005, 04:24 PM   #9
Prez420
me being from the west coast of canada.... we get ALOT of rain. Id like to have that splash guard on the engine.
where would I find one of these? finding a used one wont help either. Im sure mine was in about as good of shape as any used splash guard could have been and it STILL came off.
heat isnt a prob for me but the fact that rain on the road will be getting all over my beautifully clean car's under side at will.
Prez
Old 09-08-2005, 03:05 AM   #10
Poodles
Poodles is on a distinguished road
Splash shield is about $113 from this place...
http://www.trademotion.com/partlocat...=1&catalogid=2
Could also be the shields on the side, in front of the rear wheels...
Poodles is offline   Reply With Quote
Supra MKIV Front Grill Durandal MKIV Supra 2 10-01-2008 02:01 AM
Front Strut Bar - Quick Question Grandavi MKIII Supra 6 09-25-2008 06:03 PM
front coil spring... hangsupra MKIII Supra 6 06-03-2007 09:25 PM
