Old 06-18-2010, 03:24 AM   #1
ochowdero
Exclamation 1987 A/T supra suggestions
i need help on what to do to my 1987 supra..
any suggestions plz.. all is welcome
just need to get some ideas on what i can do
thanks
Old 06-18-2010, 03:37 AM   #2
907mge
907mge's Avatar
Could you get anymore generic?
Old 06-18-2010, 03:45 AM   #3
ochowdero
what you meen?
Old 06-18-2010, 04:10 AM   #4
Your thread can be taken in several different directions...
For instance, someone can suggest you fill it with explosives and watch it go BOOM!!!
But I'm going to assume your asking what performance mods you should do to your supra, in which case you need to provide more info. Is this turbo or non-turbo? What's been done to the car? Is it mechanically sound? What's your budget? What do you plan on doing with the car?
And welcome to the forum.
Old 06-18-2010, 09:05 PM   #5
ochowdero
ooooooooh okay i got you,
well its non turbo automatic.
my first plan was to switch my tranny to manual, but seeing how its costly and i mine as well just sell my car and go by a new 5 speed supra, i decided to check here and see what i can do to automatics...
basically i wanna put exhaust, cold air intake, aftermarket air filter, lower it without it being costly(IE: coilovers) <-- or cheap ones, strut bars, and anything else suggested..
eventually when i get a new head gasket ima put single or twin turbo on it..but again i know very lil about supras
my budget is average..a job soon so it wont matter really..so does this help out? and to clear it up my car is a 1987 toyota supra, automatic, non turbo. car is also stock!! Dx
thanks
Old 06-18-2010, 09:26 PM   #6
are you at all mechanically savey?
Old 06-18-2010, 09:28 PM   #7
batmmannn
batmmannn's Avatar
Default AUTO to 5 SPEED
Just get yourself a 5 speed that needs parts and combine the two. Sell the leftover from the auto supra on ebay to pay for mods on your 5 speed.
Old 06-18-2010, 09:34 PM   #8
ochowdero
@batmmannn
i was thinkin of doing that,
but then again, idk if i can find a shell for cheap.
if so, would i be able to drop my motor in my auto, to my 5 speed? if i ended up getting a five speed.
this was good, now im starting to want to do that lol
uhm yeah my car is mechanically good, only thing is my power steering is out and im trying to fix that, no clue how...
thanks
Old 06-18-2010, 09:40 PM   #9
batmmannn
batmmannn's Avatar
Default Motor Swap
Yes there are very little to no differences between the motors. Get a 5 speed Turbo that needs work and then you have it. You want a car that looks rough but has great potential. Often the blown head gasket syndrome scares owners into selling often there is no blown head gasket. There are many causes of overheating. People shouted get rid of it too me and I kept going till I have it all fixed, no blown head gasket even though I had white smoke, overheating, boiling out of my overflow, Many shouted BHG! It was a stripped timing belt and then a stuck new thermostat or air pockets in the heater core.
I used my Black auto 87 Supra to swap parts off of to fix my Red 5 Speed. Now my 5 speed is good to go and my auto needs parts, but between the too I now have one good running 5 speed instead of 2 broken down Toyotas.
In the long run it is far cheaper to get a 2nd car. Parts are getting very hard to find and expensive for these cars. Ebay is a good source for now, but that will dry up over the next few years as well.
Old 06-18-2010, 09:45 PM   #10
ochowdero
okay i got a question,
i like stick shift personally,
but whats the pros about a stick shift verses an auto
and the cons?
Tags
mkiii a/t suggestions
1987 supra suggestions ochowdero MKIII Supra 0 06-17-2010 11:05 AM
