Old 06-15-2010, 09:56 PM   #1
dlfred
dlfred is on a distinguished road
Default Where to buy a Driveshaft Center Support Bearing 1986.5 NA-5spd
I have search the threads and with no success in tracking down a driveshaft center support bearing. Unfortunately cost is an issue. I appreciate any help. Thanks
1986 Supra 3.0 NA Stock
5 Spd. Lexus rims 16 x 7
dlfred is offline   Reply With Quote
Old 06-16-2010, 12:20 AM   #2
reydio
reydio is on a distinguished road
There is really no other way to go about the replacing the center support bearing....you have the following options:
1. Buy OEM from Toyota, yes.....it will cost you.
2. Buy from Napa or Auto parts store....you will need to modify it to fit.
3. Lastly, you can get a 1 piece steel or aluminum driveshaft....it will cost almost the same as a replacement center bearing support, just a few dollars more. Then you don't have to worry about the center support bearing.
reydio is offline   Reply With Quote
Old 06-16-2010, 01:27 AM   #3
907mge
907mge's Avatar
You can get the oem one from magauto.com for about 200. Thats where I got mine, but then you'll have to install it yourself or pay someone. It probably is listed as about a 2 hour install. And while you are at it you might as well do all the universals.
Old 06-16-2010, 02:48 AM   #4
dlfred
In my searching, jeez o wiz, I pulled up the Horsepower Freaks 1pc. shaft.
http://www.horsepowerfreaks.com/part...veshafts//5545
It looks like the best way to go and not much more than the bearing, as reydio said. Are there any cons about the switch to 1 pc ? I will contact the manufacturer to ask what else is required during installation, anybody have any tips or help?
When I bought this car I said I wanted something to work on and enjoy to replace my dirt bike. Well, I got what I wanted. It's a solid car, but as well as the shaft bearing I have the following to do.
1) Pilot bearing
2) Ball Joints
3) Bushings
4) Struts, probably springs
5) Still runs a little rough from a vacuum leak
I love this car.
Old 06-16-2010, 02:22 PM   #5
carl johansson
carl johansson is on a distinguished road
I found it here locally (california) for 135 bucks. at an industrial driveshaft place. It is not specific to toyotas, they crossed the number and found one for me. install took less than an hour.
carl johansson is offline   Reply With Quote
Old 06-16-2010, 02:54 PM   #6
dlfred
That's great Carl. Any chance you have a invoice with their part number and phone number? I am about 100 miles from Atlanta so although I can remove it and try to find someone to match it, it would be allot easier with your info. That is great news, almost went for the $350 drive shaft. Your info will help save enough to repair something else. Thanks
Old 06-16-2010, 03:27 PM   #7
dlfred
Default Center Support Bearing- Possible Aftermarket Deal $150
I may have found a bearing at O'Reillys Auto Parts
http://www.oreillyauto.com/site/c/se...pra&vi=1360707
Anyone have any experience with this bearing fitting without mods? It has a lifetime guarantee. Maybe this will help someone else out as well.
Old 06-16-2010, 03:53 PM   #8
carl johansson
I think this is where I got mine from, give em a call - see what they run
http://www.drive-lines.com/index_auto.html
The oreily one looks like it is identical - punch in an 87 and see if the part numbers are the same - if so - you would be good to go.
I'm out the door - I will check it out better this afternoon
Carl
Old 06-19-2010, 12:14 PM   #9
dlfred
The first bearing from O'Reilly had the tabs in the wrong place. He re-ordered to be sure of the part but I expect this one will be the same. I am heading up to check it out. In the meantime, I was told by a friend at a driveshaft company that he can get me a $45 bearing and I can open my old outer and install the new rubber and bearing inside of the old cage/mount. It looks easy enough, drill out 3 spot welds and do the swap and then re-weld.
Any thoughts on this idea?
I let you know about the re-ordered bearing later.
Old 03-21-2011, 10:33 AM   #10
dlfred
Default Cheaper Driveshaft Support Bearing
O'Reilly bearing was incorrect for my car. The driveshaft shop ordered a inner bearing /rubber and peeled open the old carrier and installed the new insert. He said as long as the outer carrier was not damaged it would be fine.
5000 miles later, he was right. The carrier is working fine and even held up during the time I had a u-joint go out.
$45 is what the bearing cost me.
Driveshaft and center support bearing vibration BillW MKIII Supra 10 03-03-2010 01:51 AM
can i get some info on the center support bearing?? JZA70dood MKIII Supra 6 08-03-2009 04:01 PM
1986.5 na 5spd not starting help.. 1986.5 targo MKIII Supra 8 02-21-2008 12:56 AM
Center Support Bearing Problem purplescott MKIII Supra 0 03-27-2006 10:17 PM
