Old 06-21-2010, 10:05 PM   #21
supra_rulz
supra_rulz is on a distinguished road
ok, well i got it today and installed it right away.
http://www.facebook.com/photo.php?pi...00000216988284 (i know its facebook but w/e)
anyways so i actually pulled it off and installed it. it works great..........except for the one problem i knew was comming. the stalling. lol it kinda sucked because i was testing it and my car stalled right next to this really hot chick, i waited till she pulled away to start my car lol
so my question now is, for the resurculation thing, do i just need to get a hose and connect the outlet of the BOV to the acordion bend where the old one went?
supra_rulz is offline   Reply With Quote
Old 06-21-2010, 10:46 PM   #22
supra_rulz
another question. lol
now that i have a BOV, shouldnt the boost gauge read 0 when i'm not on the gas?
EDIT:
ANOTHER question. will getting a MAF instead of AFM help at all? and will rasing the idle rpm be a shor-term fix?
Old 06-22-2010, 03:43 AM   #23
Nope. Your turbo isn't spinning fast enough at idle to counteract the vacuum that your engine creates, so you should be reading a few in/Hg (or -psi depending on your boost gauge) at idle.
Old 06-22-2010, 03:56 AM   #24
supra_rulz
see, the thing is...its still -20 psi. same as before the install....is that normal or even ok?
Old 06-22-2010, 03:59 AM   #25
That I'm not sure of.... What vacuum line did you tap into for the gauge source? Or are you running the stock boost gauge?
Old 06-22-2010, 04:11 AM   #26
supra_rulz
i have no idea where its tapped into. i got it as is. and no its not a stock guage. how much would that matter?
Old 06-22-2010, 06:04 AM   #27
Well, different vacuum lines may see different amounts of boost pressure as well as different amounts of vacuum. You may be seeing excessive amounts of vacuum pressure because your line for your boost gauge may not be installed on an ideal vacuum line.
Old 06-23-2010, 05:56 PM   #28
supra_rulz
that makes sense. i donno, the guys i baught it from were.....not exactly taking care of the car. more like just running it for what its worth.....i actually dont know where they have it. where would the "best" or ideal place be to put the vacuum?
Old 06-24-2010, 03:40 AM   #29
Vacuum lines also have a response time, depending on the source (and I don't just mean before or after the throttle body). For example providing the wastegate actuator with a signal after the intercooler will net you more power due to the turbo having to reach a higher pressure to compensate losses imposed by the IC before it'll reach the actuator spring's pressure. The downside is that due to the significant lag you'll see surges in boost and air temp.... not so good.
Old 06-25-2010, 04:18 AM   #30
supra_rulz
ok. i will check where the vacuum line is hooked up and go from there
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
installing new intercooler 1_BAD_MK3 MKIII Supra 1 01-31-2010 12:23 PM
Installing new CD Player Cyto Car Audio and Alarms 2 12-25-2009 04:50 AM
question about installing a JDM mad_dicer MKIII Supra 7 11-12-2006 03:21 PM
Installing ALARM! jaysun MKIII Supra 4 06-21-2006 04:52 AM
