Old 05-29-2010, 04:26 AM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default turns over but wont fire.
Well, there is no spark and no fuel pressure. The other day this happened but after wiggling everything imaginable it started. So, I suspect a wiring problem. Any suggestions of grounds or anything to check would be awesome. So far i have checked the fuel pump wires....no power. The fuel pump relay clicks when you turn the key on. but the Efi main relay doesnt seem to be getting ignition voltage. That's about as far as I have gone. I was going to check the ECU next.......I hate wiring.
1988 supra turbo. In process of modding:Roll cage, seats, dp, 3" intercooler, fuel upgrades, and turbo upgrades next.
tak2099 is offline   Reply With Quote
Old 05-29-2010, 04:00 PM   #2
Start with the tech tips in the TEWD (in the back of each system's diagrams ), then start measuring voltage drop across the signal lines. I'd focus on the TCCS wiring and the Ignition circuit.
Old 05-31-2010, 11:12 PM   #3
Cameroonski
Cameroonski is on a distinguished road
I had a very similar problem. Does the check engine light come on when you turn the key to ON? Mine didn't, and it ended up being a loose fuse on drivers side kick panel (The Ignition Fuse). Whenever my car doesnt start i just give that a wiggle and it fires right up. I learned almost everything about the efi system until then, so if you have any questions i probably have the answer... including computer stuff if you test that.
Cameroonski is offline   Reply With Quote
Old 06-06-2010, 02:57 AM   #4
tak2099
tak2099's Avatar
Thanks for all of the input, I haven't had time to look into it yet, but I will most likely be needing some questions answered. Also sweet new ride Cre.....looks amazing!
Help! Car turns off and on while driving? reece MKIII Supra 3 10-06-2009 12:14 AM
Loss of power and electrical fire mister MKIII Supra 0 12-16-2008 10:17 PM
318 Turns in 11 miles totalperfektion Off Topic Forum 1 03-01-2008 02:20 AM
my 1995 supra engine wont fire gkhawk Non-Generation Specific Questions 6 08-25-2006 09:58 PM
back fire intense 7MGTE MKIII Supra 3 09-26-2005 05:37 PM
