Old 05-24-2010, 12:17 AM   #1
ReelBandit
ReelBandit is on a distinguished road
Default Headgasket questions
This is my first supra so I'm still learning. This forum has given me alot info already, but is this normal for a felpro HG to partially cover this hole? Is there something I can do about it, or just not worry?
Had to do all this work cause the guy I bought it from didnt know what he was doing, now I have to REALLY clean and lap the block. This "lump" caused #6 cylinder to be 22psi lower than the rest. The head seems to be ok, but still gunna take it to the machine shop to be sure.
Name:	Block small.JPG
Thanks in advanced.
1987 Supra Targa 7MGTE 5 speed
ReelBandit is offline   Reply With Quote
Old 05-24-2010, 01:01 AM   #2
batmmannn
batmmannn's Avatar
Default Hmmmm
In that pic I see a depressed area, is that the low spot? Anyway, this is a good time to ask a question I had on this topic. When taking a head to the machine shop on high milage car what do you do and not do to it in order for it not to cause later ring failure? I have heard of people having their heads redone and then the changes somehow cause the rings to go.
Old 05-24-2010, 01:19 AM   #3
907mge
907mge's Avatar
The idea is that if you get the head redone as far as with the valves and valve sets it will restore compression. The higher restored compression is what is said to cause the bottom end to go out.
Old 05-24-2010, 03:27 AM   #4
ReelBandit
No, it is a raised spot, I'm gunna have to work it done gently so that i dont create a low spot.
Old 06-07-2010, 05:44 AM   #5
Mike.MkIII
Mike.MkIII is on a distinguished road
Default Hg
to be honist you should throw away the felpro.. look around on-line and pick up an HKS metal HG... i picked one up for mine only $101.93 after taxes. as of bottom end engine problem after BHG repair... the biggest isue is timing... incorrect timing can cause alot of stress on old bearings and seals. P.S... remember the modified spec for the head bolts is 74 foot pounds of torque.
Mike.MkIII is offline   Reply With Quote
Replacing the headgasket burton51m Show n Tell 4 07-12-2010 04:47 AM
89 Turbo 5sp blown headgasket for sale Ms89Turbo5sp Buy/Sell Cars 1 03-26-2010 10:09 PM
HeadGasket Questions scaggsj MKIII Supra 10 08-11-2009 03:37 AM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
