Old 05-20-2010, 12:28 AM   #1
907mge
907mge's Avatar
Default New Header Bad News, Need Advice Please
So the problem is:
I went down to pick up my 1990 n/a at the exhaust shop where the header was extensively modified to fit and installed. They had to bend the down pipe and lengthen the O2 sensor wire which the location is now right in front of the cat.
So I started it and let it run for a minute or two, to warm up a little. Then I was playing with the throttle a little to see how it sounds. That’s when it went wrong, it died. I restarted it and found it easy to start but now running very rich(lots of black smoke) and really rough .
So my thoughts are that the o2 sensor might have got fouled by the burning of the paint because I had repainted the whole header before it was installed. I will be going back down to the shop tomorrow since the car is stuck there. I’m just trying to get some advice since I want the shop to look at it before I start messing with it. I did not disconnect the o2 sensor since it was hard wired in. That was my first thought. So any help is much appreciated, Thanks.
Old 05-20-2010, 12:44 AM   #2
batmmannn
batmmannn's Avatar
Default Thats a strange one
I don't know much about the O2 sensor. Curious as to why you would think it could cause the car to die? Back Smoke usually means carbon being burned doesn't it? I have only seen that during fuel injection cleaning and such, Thanks, Scott
Old 05-20-2010, 12:48 AM   #3
907mge
907mge's Avatar
Because the o2 sensor ajusts the fuel/air mixture my measuring the oxygen in the exhaust, hence the name.
Old 05-20-2010, 01:31 AM   #4
batmmannn
batmmannn's Avatar
Default Ok
OK thats cool, but how can that lead to burning black smoke? Anyway Thanks for all your help I found my problem on the red Supra you have been helping me with the timing belt must have jumped. The belt is in real bad shape but not broken. Cracked and missing teeth. Timing marks are off by quite a bit! Has to be why it died. I will come back to this thread though and hope to learn more about the O2 sensor. I have never replaced one or had to. Thanks, Scott
Old 05-20-2010, 02:05 AM   #5
turbonicsperformance
turbonicsperformance is on a distinguished road
So the problem is:
you painted the inside of your exhaust? also the toyota o2 is wierd it could just be because of its placement it reads completely backward of a normal o2 i doubt it would cause this though my o2 is bad and i run 15.0 -15.7 afr at idle warm and 11.3-13.0 afr at wot 3rd gear on a 700-6500 rpm pull the shop might have just missed something or left something unplugged
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 05-20-2010, 02:13 AM   #6
907mge
907mge's Avatar
I didn't paint the inside on purpose but i'm sure some paint made its way in there.
Old 05-20-2010, 02:18 AM   #7
just overspray wouldnt be enough to foul your o2 its built to have carbon chunks thrown at it and its always coated with unburnt fuel and carbon
howd you like the sound before it died though?
Old 05-20-2010, 02:23 AM   #8
907mge
907mge's Avatar
it sounded good but cost way too much
Old 05-20-2010, 02:28 AM   #9
do you know what all needed to be modified? besides the dp
n/a advice dj7mge MKIII Supra 0 07-25-2009 06:19 AM
Buying supra need advice guys sisqojazz Non-Generation Specific Questions 1 03-21-2007 10:47 PM
good news bad news and whazzzzuppp supras sharkn MKIII Supra 5 10-09-2006 04:23 AM
***Need expert advice on a 2JZGTE swap in a Lexus*** sixfourbolt Non-Generation Specific Questions 4 08-27-2006 08:30 PM
header supra_91 MKIII Supra 4 04-13-2006 10:36 PM
