Old 05-14-2010, 12:02 AM   #1
Jay633
Jay633 is on a distinguished road
Default boosting wrong. help please
hey my car just got back from shop because headgasket job. before the boost gauge would rise, but now it doesnt. were is the connections to see if they misplaced them??. when driving doesnt feel as quick. gears dont pull as much. takes forever to get to 60. suggestions?? and yes im getting aftermarket boost gauge
Jay633 is offline   Reply With Quote
Old 05-14-2010, 04:11 AM   #2
Sounds more to me like an intake coupler is off, loose or has a big tear in it.
The boost gauge's sensor is by the cruise control actuator behind the front driver's side wheel well... it is not used by the ECU though so while the gauge won't read anything it wouldn't affect performance at all.
EDIT: And check for error codes, the details are in the MKIII FAQ.
Old 05-15-2010, 05:17 AM   #3
Jay633
ok so now its boosting correctly according to aftermarket gauge. still feels kinda wierd, whats stock boost 5-psi??
Old 05-16-2010, 07:20 PM   #4
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Default Stock Boost
I believe its computer limited at 7.3 PSI
Old 05-16-2010, 07:53 PM   #5
No, the ECU has no idea what boost level you're running. The only control is the wastegate actuator (and boost leaks). The acceptable boost range is something around 9 to 6psi (I can't remember right now, it's in the TSRM though if you wish to look it up)... it's not uncommon for the wastegate actuator's spring to weaken over time causing a drop in boost pressure.
Old 05-16-2010, 08:22 PM   #6
Bru
Bru's Avatar
I have added 3.5mm of washers under the waste gate bracket to shim it up.
Old 05-16-2010, 10:26 PM   #7
Bad idea. You limit the range of motion of the actuator and open yourself up to the possibility of boost creep and running lean. Just build a cheap manual boost controller... they're very easy to make and a decent bit safer to run.
Here:
http://www.gusmahon.org/html/boostcontrol.htm
Old 05-18-2010, 07:03 PM   #8
MIKEFMKIII
MIKEFMKIII's Avatar
MIKEFMKIII is on a distinguished road
Default boost problem
ok so leme start i replaces plugs and wires. replaced intake tube. checked for leaks cant seem to find any. my problem is if i slowly give full throttle i boost great but if im on it hard it boosts half way up the rpms then feels like it starts to miss. at idle i smell fuel and it spudders every 3 seconds not a misfire spudder but like a blank spot hard to explain more like grrrrrrrrrrPgrrrrrrrrPgrrrrrrr if thats understandable. also if im quick shifting under full throttle it falls as soon as i shift gears and hit throttle again there is a noticable miss but instantly comes back. only throws check engine light if im on it hard. any ideas??????
MIKEFMKIII is offline   Reply With Quote
Old 05-18-2010, 07:44 PM   #9
if the check engine light is coming on at all you need to check for codes. critical codes may only cause it to light up momentarily... many codes don't trigger the light at all.
Old 05-18-2010, 09:17 PM   #10
ReelBandit
ReelBandit is on a distinguished road
What can you boost safely on a stock setup?
ReelBandit is offline   Reply With Quote
Audio and a lot of other things wrong with car bluemeate MKIII Supra 4 05-18-2010 07:07 PM
Boosting my 88 7mge lemonhead4696 Non-Generation Specific Questions 5 07-02-2008 02:24 AM
carfax report. (sorry earlier posted to wrong category) supramkiiiboost Non-Generation Specific Questions 0 09-21-2007 10:45 PM
My fenders look wrong Kristian_Wraae Non-Generation Specific Questions 14 05-07-2007 03:20 PM
Stock Block Evilfurby MKIV Supra 56 01-09-2006 02:23 AM
