Old 05-13-2010, 11:47 PM   #1
dlfred
dlfred is on a distinguished road
Default Intake Pipe Connector Question
What is the purpose of the inline cannister looking part between the MAF and the TP? Is it important to keep that on the car or can you eliminate it?
I don't want to do anything to hurt performance. I was considering a flex hose to replace the 90 at the TP and the piece I have will reach to the MAF.
Might look....tacky, I don't know.
http://www.cygnusx1.net/Media/Supra/...es/MA8879C.gif
It is #17875
1986 Supra 3.0 NA Stock
5 Spd. Lexus rims 16 x 7
dlfred is offline   Reply With Quote
Old 05-14-2010, 12:05 AM   #2
907mge
907mge's Avatar
Like on most cars I belive it is to keep the intake quite.So it can be removed like most people do. And you don't have a maf you have a afm(air flow meter). Don't use a flex pipe. The idea is to make the air flow as smooth as possible. I would recommend aluminum pipe and silicone connectors.
Old 05-14-2010, 12:34 AM   #3
dlfred
Good deal and thanks for the picture. Very nice.
Old 05-14-2010, 04:00 AM   #4
It's a helmholtz resonator... it doesn't just quiet the intake, it removes oscillations (turbulence). Removal due to ignorance is not an excuse... if you don't know, look it up... I know, hard to say as there's so much bad info on the net these days.
Old 05-14-2010, 11:05 AM   #5
dlfred
Figured there was something to it, so what you are saying CRE is that you should not remove it? What will removing it do to performance?
And by the way, this is looking it up for me.
Old 05-14-2010, 07:53 PM   #6
907mge
907mge's Avatar
I never noticed a problem nor a decrease in preformance or mpg's. With so many people taking them out, wouldn't more people have said something. Unless there is some solid proof to keep it in i'd leave it out.
Old 05-14-2010, 08:28 PM   #7
people are idiots.... I don't claim to be the exception. do some research. there's a great article out there about why Yamaha spends MILLIONS on designing their resonators.
Old 05-14-2010, 08:50 PM   #8
907mge
907mge's Avatar
Then why does my 2zzge designed by yamaha run better with the K&N Intake with just a curved open pipe.
Old 05-15-2010, 01:25 AM   #9
It most likely doesn't, you may just be imagining it in most places in the power curve. The resonator is a neutral device in some locations in the curve, like any musical instrument they're tuned for a very specific range... the weak spots.. that's where the most noise is made and as such where performance takes the biggest hit. In some systems this hit is minimal due a more efficient design of the rest of the system, staged throttle bodies and so on. There are also very different types of noise removal devices... some really are only for making things quieter and some do cause a small level of restriction... not the case here.
Here, read through the following link... last time I'm searching info for others. There is a TON of information about this topic by people far more qualified than garage motor heads who half drunkenly assume that added noise = more power.
http://www.supramania.com/forums/sho...ight=helmholtz
K&N makes VERY poor filters by the way (this too is available on the net )... let's also cut to the chase on a couple other things while we're at it: larger diameter intake AND exhaust piping are not always a good idea (ESPECIALLY on a N/A); and a larger air filter that's sitting in a hot engine bay, sucking up air that's 20 degrees or more above the outside air temp causes BIG losses in power. You don't see a huge change in mileage because you're actually getting LESS air.
I'm done. Find your answers and think what you like it's obvious I'm not going to convince you and you're definitely not convincing me.
Old 05-15-2010, 12:30 PM   #10
dlfred
Smile
Cre,
I thought that asking questions and discussing possibilities was one of the benefits of a forum. I did some research but since I consider this site a research spot. I don't mind looking around for answers but what I found here was a concentrated source of info. I am new but without this forum I would have struggled much more. I don't adhere to every opinion posted, it is my responsibility to determine if the info I get is usable. The value of what each person has to say can be supported or dismissed all on the same page.
You have a huge impact on the site when it comes to solid tech help. I appreciate it. If this has become a burden or thorn in your flesh, I get it. I have similar experiences in the motorcycle industry, stupid people are out there.
If I am using the forum incorrectly I would prefer you tell me.
5mge intake manifold upgrade Allen Crump Non-Generation Specific Questions 1 11-02-2006 01:53 AM
NA Intake pipe?? Dejvid1785 MKIII Supra 16 10-14-2005 03:09 AM
