NGK plugs I can t remeber the specific kind but i would say do a search on this and you wil find gobs of info. I even listed some in the past but i just cant remember the model number 6444 or something. they are a cold plug and i set mine on my 1j to .028 gap
1JZGTE ,R154, Hallman Boost Controller, HKS bov, HKS Mushroom top Air Filter, HKS Front Mount Intercooler, Greedy Turbo Timer, PLX300 AFC, Custom Divorced Y-pipe, Custom Intercooler Pipeing, RS-R Concept Exhaust, Optima Red Top Battery, Strut bar Brembo Rotors, A1 Traction arms, Megan Coilovers, Stern ST 2 wheels rear 265x30 r19 - front 245x35 r19, New Front Lip, 18 x 8 and 18 x 9 MRR HR2 with whatever for Drift treads 2 additional C12A turbo's(Extra) |
#3 | |
is that an iridium plug? |
i am Not sure I think it is nothing special (copper maybe) it just stays in the correct heat range to maximize output.
In the TSRM it says which plugs to use, all I can remember off the top of my head is 7MGTE's use a double platinum NGK plug with a heat range of 6....
Straight from the TSRM: 7MGTE- NGK BCPR6EP-N8 7MGE- NGK BCPR5EP11
#6 |
Don't run cooler plugs unless you really need cooler plugs... they'll just foul. There's no additional power to be made from just running a cooler plug for the hell of it.
As for the plugs, I don't care for the "boutique" bull $h!t... just stick with NGK copper or platinum plugs.
#7 |
Any problem with running NGK iridium s since that what i'm using now? My 2zzge uses them but it is a higher compression motor.
#8 |
I ran those the entire time my car was N/A with no problems at all. I just don't think they're really any longer lived than platinums and their actually less conductive.
The whole copper vs platinum vs iridium thing is more a matter of laziness than anything. In the end none costs any less than the other, it's more to do with the frequency of replacement.
#9 |
the e3 plugs suck ass. they foul out really quick. my cousin threw them in his wrx with 3" turbo back exhaust intake and stage 2 tune and they fouled out within like 3000 miles
#10 |
Running colder heat ranges on stock hp levels is no good, i run bk7re's i believe thats one step colder than stock but im making more hp.
I head bad things about e3's |
| Help...My spark plugs are in the oil !!! | chinesedawn | MKIII Supra | 6 | 10-03-2011 09:25 PM |
| Spark Plugs and Water | cgreiner | MKIII Supra | 1 | 07-21-2009 03:49 AM |
| Spark Plugs (1G-GE vs 7M-GE) | makemedie | Non-Generation Specific Questions | 5 | 10-26-2008 05:19 AM |
| NGK Spark Plugs | 91 Supra | MKIII Supra | 5 | 08-07-2007 03:52 AM |
| 1986.5 with blown Head Gasket - Removing Spark Plugs | unkymurch | Non-Generation Specific Questions | 10 | 03-02-2007 06:48 PM |
