Old 05-04-2010, 09:09 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default 7MGE swap
So over the last few months my 7mgte developed and currently has a rod knock. (i know im stupid for running it low on oil but dont hate on me). Anyway on to my point, has anyone swapped in a 7MGE in place of a gte? and if so what all is necessary for the swap. i have a complete 7mge, w58 tansmission and all wiring/ecu. I just want to know what has to be done to make the swap work.
any help is greatly appreciated. any disrespect is not. thank you
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 05-04-2010, 09:23 PM   #2
907mge
907mge's Avatar
Why would you downgrade?
Old 05-04-2010, 09:28 PM   #3
supraluver4life
I know it sounds retarded but for the milage. even 3 or 4 mpg would be better, saying im getting like 15mpg. but its also so i can start building my 7mgte. (i do have two though). And the rod knock makes me super mad and i just wanna tear down the block fix the rod knock, change the valve guides, change the timing belt, and put in a mhg.
+300rwhp
Old 05-05-2010, 04:29 AM   #4
A healthy GTE should get better mileage than the GE... they did from the factory. Your horrible mileage is due to the engine problems, not the turbo.
Running a lower octane will generally increase your mileage as well.
I'll try to help with individual questions, but I haven't the time to post a writeup or to watch the thred like a hawk. IMO, 95% is obvious.
I recommend keeping the oil cooler setup from the GTE.
Are these from the same revision? Pre89 to pre89 or 89+ to 89+??
Old 05-06-2010, 01:54 AM   #5
supraluver4life
alright great thanks and yes they are from the same revision. both are 87s
+300rwhp
Old 05-06-2010, 04:05 AM   #6
supraflymkiii
supraflymkiii's Avatar
supraflymkiii is on a distinguished road
everything should bolt in and plug in. Obviously you need to swith to the non turbo coil and all other non turbo items. You could also leave the turbo transmission in if you want.
supraflymkiii is offline   Reply With Quote
Old 05-06-2010, 09:01 PM   #7
supraluver4life
i dont thing ill leave the turbo transmission but great and thats basically what i already knew, i just wanted to make sure. thank you for the help
+300rwhp
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
7mge swap, electrical problem 89n/aA/T-2turbo5spd MKIII Supra 5 08-15-2007 06:51 AM
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
Engine swap 5mge for 7mge eternal genome MKII Supra 12 03-04-2006 09:20 PM
7mge to 7mgte without swap? Stuba MKIII Supra 1 10-18-2005 03:37 AM
