Old 04-29-2010, 09:36 PM   #1
.Andrew.
.Andrew.'s Avatar
.Andrew. is on a distinguished road
Check the bolts on top of shock towers, make sure sub frame bushings are intact and the bolts are tight. Check to make sure bushings on lower control are intact and bolts are tight. Also if it does it over speed bumps, the motor motor mounts could be cracked or chunks missing out of them which causes oil pan to smack cross member. I wish I had Pics...
.Andrew. is offline   Reply With Quote
Old 04-30-2010, 02:38 PM   #2
amueller626
amueller626 is on a distinguished road
You wish you had pics to show me or from me to look at?
Thanks,
Bill
amueller626 is offline   Reply With Quote
Old 04-30-2010, 02:41 PM   #3
.Andrew.
.Andrew.'s Avatar
I will take some soon and attach on a reply.
Front and rear bumper removal CanadianBak'inSupra MKIII Supra 0 11-24-2009 03:18 PM
Noise near front of engine when clutch is engaged. Kuanos MKIII Supra 4 08-28-2009 07:47 PM
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
front coil spring... hangsupra MKIII Supra 6 06-03-2007 09:25 PM
