#1 |
not sure what you did with the lights, but your tac. will not work. you will have to replace the cluster or run an aftermarket one, you can get the signal from the little plug on the side of the diagnostic box
motor swaps are a sad result of a non tuner! If its a 7m / leave it a 7m |
#2 |
see thats the thing, all i did was wap engine harness, i didnt touch the lights, its really weired,
#3 |
and i do have all of the gauges for the turbo engine, just no the cluster that holds them, if i install them will i get a tach reading
#4 |
the difference is in the dash harness, you need to trace the black wire from the coil packs to where it meets the dash harness and see what color the wire switches to and run that wire to the tach
#5 |
cool, thankyou, and any advice about the headlights?
#6 |
well the head lights are a ground switch, so you mush have pinched a wire or grounded 1 out wile doing the swap. first place to check would be by the battery. check for a frayed harness.
#7 |
sounds good, i will take a look tomorrow, thankyou for the help
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 7mgte swap vs 1jz swap | Supra Saiyan | MKIII Supra | 15 | 04-24-2012 02:58 AM |
| Headlights won't turn off. - was: Need some help plz!!! | kusupra3 | Non-Generation Specific Questions | 15 | 02-08-2010 12:52 AM |
| Headlights going bonkers! | RNEMESiS42 | MKIII Supra | 3 | 12-17-2007 08:39 PM |
| 1JZGTE swap question | supradaddy0803 | MKIII Supra | 1 | 04-12-2007 04:56 PM |
| 89 Supra Turbo w/1JZ Swap Problems | Donnies Foreign Car | Non-Generation Specific Questions | 1 | 02-02-2006 05:03 PM |
