Old 04-10-2010, 01:12 AM   #1
jason7504
jason7504 is on a distinguished road
Default idle's fluctuating?
hi guys,
I just got a 87 NA supra and it runs pretty good but i noticed at idle it kind of fluctuates, what do you think is causing this? how should i diagnose this?
jason7504 is offline   Reply With Quote
Old 04-10-2010, 01:32 AM   #2
Start with what's suggested here: http://www.toyota-supra.info/forums/...le-issues.html
Possibilities include: TPS, AFM, Vacuum Leak, Intake Leak, misfiring, improper ignition timing
Old 04-10-2010, 01:52 AM   #3
jason7504
here's a video
Old 04-10-2010, 04:18 PM   #4
jason7504
does that video point to anything specific?
Old 04-16-2010, 12:15 AM   #5
jason7504
would low oil pressure from some leaks cause the idle to fluctuate?
Old 04-16-2010, 04:50 AM   #6
What have you actually checked?
Old 04-16-2010, 06:47 AM   #7
jason7504
well i know there's a few places that leak oil such as the valve cover gasket but not sure how to check to see where the vaccum leaks might be, heard something about using brake fluid or something but not sure what the best way to do it is
Old 04-28-2010, 10:55 PM   #8
jason7504
i think the spark plugs are misfiring because oil is leaking from the valve cover into the spark plug tubes
supra idles but will not drive bigv Non-Generation Specific Questions 0 03-12-2008 03:58 AM
Fluctuating Temp igosaur MKIII Supra 3 08-18-2007 11:05 PM
Idles low and dies at stop Chomper MKIV Supra 0 02-09-2007 05:19 AM
I need help! My supra idles rough at cold starts...=( idoke MKIII Supra 6 09-19-2006 02:55 PM
Whats Wrong? Idles Like Nascar tonystarks MKIII Supra 3 05-18-2006 02:45 AM
