Old 05-02-2010, 02:46 PM   #3
corrosivecopper
corrosivecopper is on a distinguished road
That depends on what you wanna do and how often that engine is coming out. I just got the ARP bolts (your first link) and they're absolutely fine for leaving the engine in the car if ya need to remove the head. Using the studs (2nd link) are much better for the sake of torquing down and more easily lining up the head on the block, but the head doesn't come off there easy while the engine is in the car. You're required to pull the head straight up, and it doesn't quite clear to firewall. For serious racing, I'd say studs for sure. For the street, bolts work, but be sure to torque them more than factory spec. I torqued my bolts to 75ft/lbs. The choice is yours
87 Supra 7MGTE
Stock.. for now
corrosivecopper is offline   Reply With Quote
Head Studs 907mge MKIII Supra 0 03-15-2010 12:16 AM
ARP Head Studs frostburn MKIII Supra 4 08-22-2008 03:50 AM
Head Bolts, Or Head Studs?? ZauggIt1 MKIII Supra 2 08-08-2006 01:23 PM
Torque Specifications (ARP Head Studs)??? Dejvid1785 MKIII Supra 5 03-06-2006 02:59 AM
