Old 01-11-2009, 04:29 AM   #1
elmer
elmer is on a distinguished road
Default 86.5 auto transmission removal HELP!!!
I am new to this forum but had this supra for 5 years it died on me 2 years ago and i just got a transmission to replace the bad one. I started to removal the old transmission i took out 2 hard line that was attached to the transmission, ?the shift linkage? (the 2 inch lever on the transmission that changes gear), 3 electrical connector, the metal cable and 7 bellhousing bolts. i am having trouble with the last bolt that hold the engine and the transmission together. it the one below the intake manifold and above the firewall. i dont want to buy the complete manuel to the car because im going to Texas Aircheck the car so please any diagrams and experience in transmission removal and installtion? anything would be very helpful thank you
elmer is offline   Reply With Quote
Old 01-11-2009, 05:02 AM   #2
Chambers
Chambers's Avatar
Well, be glad there are a few places on line that have the entire Toyota Service book for the Supra. Here is one, it should have all the info you need, good luck!!
http://www.swaqvalley.com/TSRM/15_AT.pdf
"Stuck in the 80's"
Old 01-11-2009, 05:07 AM   #3
elmer
i was just looking at this, this seem to show me everything about the transmission but not how to remove it from the car or seperate it from the engine really
Old 01-12-2009, 12:35 AM   #4
Chambers
Chambers's Avatar
Is there any chance that you could get a few pictures of the problem bolt, that might help with giving advice.
"Stuck in the 80's"
Old 01-12-2009, 08:35 AM   #5
CyFi6
many people use a bunch of extensions with a universal joint adapter and get to them from under the car
Old 01-14-2009, 12:44 AM   #6
Busted Knuckles
Busted Knuckles's Avatar
That is exactly how I got my manual transmission unbolted. But it was one swivel and a 36" extension. Thank god for Sears Craftsman. Also, for automatics, I suggest you remove the flywheel cover and unbolt the torque converter from the flywheel, and remove it with the transmission.
Old 01-06-2010, 04:08 PM   #7
11Ton Butterfly
11Ton Butterfly's Avatar
11Ton Butterfly is on a distinguished road
I'd like to thank you guys for the info I'm having the same problem and found this on a google search.
11Ton Butterfly is offline   Reply With Quote
Old 04-06-2010, 05:17 PM   #8
Diovox
Diovox is on a distinguished road
I have an 88 Toyota Supra Turbo. I am trying to replace the transmission and I am having trouble getting at the nut above the starter(hopefully the last one). I can see the bolt but i have little to now room to move a wrench and a ratchet wont work either. Is there something else I need to remove before trying to take this nut off?
Diovox is offline   Reply With Quote
Old 04-06-2010, 10:41 PM   #9
Busted Knuckles
I've had to do this 3 times in a row over 2 days, then another time removing the transmission. My trick was to use a 14mm (or was it 17mm) box end on the nut just above the starter, and use a ratchet with a loooooooong extension to get to the bolt head on the transmission side from underneath. Still a PITA, but it worked.
Auto Transmission Swap big_kahuna89 MKIII Supra 1 06-13-2008 11:13 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
Buzzing Auto transmission MattJ MKIII Supra 2 02-21-2006 10:40 AM
