Old 04-03-2010, 02:23 PM   #1
Rob1
Rob1 is on a distinguished road
Default Intercooler
Does anyone know a good intercooler that is compatable with 1990 supra turbo, cuz the one i have has input and output on opposite sides of intercooler. i think i need one that has input and output on same side of intercooler. anyone know a good aftermarket one?
My work in progress!!!
1989 toyota supra turbo targa top 7mgte, Five speed left hand drive.
Rob1 is offline   Reply With Quote
Old 04-03-2010, 07:57 PM   #2
There are plenty of side inlet IC's out there like this one: Siliconeintakes' side inlet/outlet. You'll need to use a couple angled couplers, but they work fine. Otherwise, for a direct fit, you can look for a "Spearco" replica IC... I think Horsepowerfreaks.com carries them.... but anything but a generic universal is EXPENSIVE.
Old 04-04-2010, 12:51 AM   #3
I would search around and ask on acouple different forums the precise question you need answered..
I have a ebay universal IC. what piping route did you use. did you have to CUT anywhere? Ive seen pics of aftermarket ic's were it would normally connect to the 3000 pipe connect to the front engine facing side of the intake manifold. whats up with that? howd you make that work? whats the upsided.. I would like to know these answers also.
post if you find any results.. good luck
Old 04-06-2010, 04:42 AM   #4
Rob1
Default ic piping
I talked ot a guy who said he ran the hot air side from bottom of turbo to the driver side of universal ic with a 180 degree bend to meet ic input, then ran the cool air side back through stock location to the 3000 pipe would that be a good idea?
Old 04-06-2010, 10:26 PM   #5
if the 180 degree bend is the only way.. whats the downfall to it? not enough room? low clearance?
if it works go for it. seems like thats the only way.
Old 04-07-2010, 01:28 AM   #6
Rob1
yeah thats the only way i can see, ill try it and post how t works, im just a little worried about that bend causing a high pressure spot and popping one of the connectors off the piping cuz it will have to be a sharp 180 degree bend
Old 04-07-2010, 02:09 AM   #7
It's a VERY common setup, don't worry about it too much, but get piped with rolled beads for the 180 at least.
Old 04-07-2010, 02:47 AM   #8
Sound advice.
Old 04-07-2010, 04:45 AM   #9
Rob1
Sound advice.
Ok thanks guys, now i am on a very tight budget(but arnt we all lol) what kind of pipe should i use for the ic plumbing? i have a bunch of random peices of what looks like chrome but im no sure what the acctual metal is, I dont want to use any kind of plastic either. thamks
Old 04-07-2010, 05:11 AM   #10
aluminum is the standard piping used for aftermarket IC's. you could opt for using the same "soft" piping that comes stock with your car. probably cheaper and just as reliable while maintaining that "stock" appearance
Next step: The Intercooler azerty Non-Generation Specific Questions 1 08-19-2009 09:22 AM
Clean out your intercooler!! IHateHacks MKIII Supra 4 10-25-2007 08:33 AM
Intercooler restriction? gomezmk MKIII Supra 0 03-03-2007 02:11 AM
Which Aftermarket Turbo? Intercooler? RoLLiN MKIII Supra 1 06-10-2006 06:57 AM
intercooler Mkiv shadowmaster05 MKIV Supra 1 03-20-2006 02:08 PM
