Old 03-29-2010, 04:07 PM   #1
2genfun
2genfun is on a distinguished road
Default new injectors quick question...
so i have a na 88 and just put turbo injectors in it...now i cuts out at wide open throttle...thats normal right? i need a better pump?
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 03-29-2010, 07:25 PM   #2
No, it's not normal. and why did you install GTE injectors? You're probably flooding. : p
Old 03-29-2010, 07:54 PM   #3
907mge
907mge's Avatar
when I asked if my stock injectors were going to be good enough after a port and polish, I got the answer "they are hard to max out with the 7mge"
the main thing is you don't need more fuel if you don't have the air for the right air/fuel mixture
turbo=forced air
Old 03-29-2010, 09:22 PM   #4
2genfun
so it should be fine once i put the turbo on then right?
Old 03-30-2010, 12:05 AM   #5
That's not a given you need to tune really... and even running rich it shouldn't be flat out falling on its face at WOT, IMO. Getting black smoke? Have you checked for error codes? Any holes in the intake? Is the AFM in good shape?
Old 03-30-2010, 03:24 PM   #6
2genfun
no smoke it just when u get past like 4k rpm it wont go past that...im sure im flooding it if the ge injectors can handle boost...cuz it runs fine and all it just past 4k it has trouble
Old 03-30-2010, 09:45 PM   #7
GettaRobo
GettaRobo is on a distinguished road
Just letting it be known that I've been experiencing this EXACT same problem of not being able to get above 4k rpms. I'm wondering if replacing the injectors would solve this? That was to be my next course of action with my 88 NA since I've tried virtually everything else. The problem with mine is that I have no clue what the guy before me did to the car. It has only 132,000km on it though.
PS. Sorry, I don't mean to hijack the thread, but if anyone has any suggestions for our pesky problem, it would be greatly appreciated.
Edit: Additionally I can add to this thread. My car cuts out at full throttle as well and I HAVE changed the fuel pump, so you can save yourself a few hours of frustration.
GettaRobo is offline   Reply With Quote
Old 03-31-2010, 01:19 PM   #8
Let's try again....
Old 03-31-2010, 11:10 PM   #9
2genfun
k no smoke. No error codes. no holes in the intake. i put everything back where its supposed to go. and the maf is fine i just replaced it...help?
Old 04-01-2010, 12:29 AM   #10
The GE injectors are not enough for any appreciable amount of boost... maybe 3 to 4 psi.... What was meant was that even a built up 7M-GE is rarely capable of moving enough air to require larger injectors. That doesn't include N/A-T applications.
So the AFM is new? Does the car choke over 4K regardless of the throttle position or only when floored?
Quick newb gauge cluster question Calm Like A Bomb MKII Supra 4 08-20-2009 08:55 PM
Quick question Curtis MKIV Supra 10 04-30-2009 03:15 PM
quick question need answered quickly switchblade Non-Generation Specific Questions 5 07-21-2007 12:47 AM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
