Old 03-22-2010, 08:21 PM   #1
supraluver4life
supraluver4life is on a distinguished road
Default fuel problem?.... i think
so i have a 1987 toyota supra turbo. fairly stock, full three inch exhaust with a divorced downpipe, new apexi intake filter, and a stage 3 clutch. so my problem i beleive is related to fuel. so heres what happens. when i have around a quarter tank off gas and i go for a hard pull (WOT) it accelerates and then cuts out, then accelerates then cuts out. it does this quite a fe times durring acceleration. then even if i dont floor it, say 1/2 throttle, it does it still does it. its like vroo... vroo... vroo (with a little wheel slip in between), instead of vroooooom! I am really confused about what the problem is. it seems like it is hitting fuel cut but i am only running 6-8 psi. and it only ddoes it when i have 1/4 tank of gas or less (which is most of the time lol). I am thinking maybe the fuel pump is going? but idk. about six months ago it was doing it really bad, when i had more than a half tank of gas. then i changed the fuel filter and it sopped for a few weeks. the filter i pulled out had fairly cleen gas going in one side and on the other side dark redish brown gas came out. after it started happening again, i changed the filter once more. and this did nothing. still does it. but when i pulled out the second filter it wasnt very dirty. so basically what im thinking is that either i have a terribly filthy gasolina tank or my fuel pump is about to hit the shits. im not sure but any feedback about this would be greatly appreciated. thank you in advance!
i will try to take a video off it within the next week or two but i am out of town and wont be back to my car for about a week or so.
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
Old 03-25-2010, 02:29 AM   #2
Cameroonski
Cameroonski is on a distinguished road
I replaced my filter on my 86.5 and it obviously had some bad rust in it. My fuel pump died the next day. So i take my tank off and it is very rusty and my pump was all gunked up. So i cleaned it out many times with water, then gas, then let it dry for several days. New fuel pump (ebay - $20 ) and put it all back together. Put a FULL TANK of 93 octane good quality fuel in and a can of sea foam (or stablizer or whatever to clean that stuff out). I noticed a difference in power with the new filter and new pump. So when your almost out of gas you could take your tank off and take a look (easier said then done). Or there is an inspection plate in the trunk where you can take the fuel sender unit out. But I would say that you have a rusty tank that needs cleaning, a fuel pump on its last legs, and some gunk in the system - because thats what I had . Good Luck!
Cameroonski is offline   Reply With Quote
Old 03-25-2010, 02:57 AM   #3
2genfun
2genfun is on a distinguished road
um u probably have a lot of gunk inside ur fuel tank...so when u have more than a 1/4 tank its diluted enough to run until theres more rust than gas...
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 03-25-2010, 02:32 PM   #4
midwestmk2
midwestmk2's Avatar
midwestmk2 is on a distinguished road
+1 good luck
83 p-type,5spd,4;10 gears,New 86 cressida 5MGE 195hp,HKS metal head gasket,Cressida injectors,d-port intake runners,No EGR,No cat,Tweaked MAF,Custom cold air intake,Custom rear strut bar,Perfection clutch,Custom 3inch exhaust,4inch bazooka muffler,,Only 2700lbs,, COME AND GET IT!IF YOU DARE!! Please no Honduuuuhhhs!!!
http://www.cardomain.com/ride/858848/2
midwestmk2 is offline   Reply With Quote
Old 03-27-2010, 12:21 AM   #5
supraluver4life
this is all basically what i figured. i just needed some more oppinions before i dumped money into the situation. thank you all for the help.
+300rwhp
Old 03-27-2010, 05:09 AM   #6
MA70-3.0GT
MA70-3.0GT's Avatar
Best of luck with that, just wanted to say that's about the truest words ever spoken in that sig. Haha
just one thing to add though, obviously the rust says the tank needs looking at and quick, but on the off chance it still isnt sorted after that, i had a similar issue caused by a dodgy AFM that didnt throw an eml but must've read low hence sending the thing lean.
Old 03-27-2010, 06:19 AM   #7
supraluver4life
wow thats interesting. i happen to have an extra afm so ill throw that in, run down the tank and see whats up. dont know if that will fix it but hey, it cant hurt anything.
+300rwhp
fuel problem?.... i think supraluver4life MKIII Supra 0 03-22-2010 08:20 PM
Lipp Fuel Rail Problem sprigmo1 MKIII Supra 3 02-26-2009 06:03 AM
Problem with fuel injectors! teedoff00 MKIII Supra 3 07-30-2008 05:03 AM
1980 Supra Fuel pump problem Zebian2 Non-Generation Specific Questions 2 11-20-2005 03:21 AM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
