Old 03-13-2010, 01:58 AM   #1
chinesedawn
chinesedawn is on a distinguished road
Exclamation Help...My spark plugs are in the oil !!!
My car runs good but eat lots of gas and don't have the power it suppose have after 2nd gear
one of my friends (who has a same year supra) driven my car today and he said his supra has much more pull than mine, 7300 feet altitude could affect some power output but should not that much
I checked my air filter and spark plugs(# 1, 2 and 6) , air filter is pretty dirty but the worst parts is my spark plugs!
Here is the picture, god, oil is full around the spark plugs......
Anybody know why? Any good ideas? Do I have to replace all the spark plugs?( I wish not, I don't want move the intake again....)
chinesedawn is offline   Reply With Quote
Old 03-13-2010, 02:35 AM   #2
907mge
907mge's Avatar
It is either one of the valve cover gaskets or one of the four plugs on top of the head. I found when I removed my head that only 5 of the 6 cylinders were firing. The one not firing had the most oil in the plug hole.
Old 03-13-2010, 02:35 AM   #3
Green7mgte
Supra Forum Moderator
valve cover gasket. lots of good posts on this. give it a search.
in the mean time read this
http://www.toyota-supra.info/forums/...ark-plugs.html
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 03-13-2010, 04:44 AM   #4
chinesedawn
Thumbs up
Thanks very much!
Old 05-24-2011, 12:14 PM   #5
interested!
Smile oil on spark plugs
Hi!
Your oily plugs are due to leaking oil gallery (14mm hex drive ) plugs , mine did this too! the rubber o-ring under the plugs had carbonised and cracked causing the slow leak by pressure/gravity into the adjoining plug hole.They are VERY TIGHT - take care when trying to remove -I used a 1/2 inch drive power bar and a good quality 14mm hex drive and short extension- could have done with some help to hold the extension straight - -you will need some new o-rings to cure the leaks , also a good idea to change the cam cover gaskets, I also changed the clamping screws for 6mm (10mm hex drive ) bolts to get a better clamp-up - no leaks now!
Old 10-03-2011, 04:48 PM   #6
icey756
icey756 is on a distinguished road
clamping screws? Im confused at that part.
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
icey756 is offline   Reply With Quote
Old 10-03-2011, 09:25 PM   #7
interested!
Hi! The clamping screws are the screws holding the cam covers to the cylinder head, I changed these screwdriver type screws for hex head bolts,still using the original rubber gaskets and cupped washers, this gives a better clamping pressure to stop the cam cover gaskets from leaking, also much easier to tighten when everything is back in position .Hope this cleared up any confusion !
Spark Plugs and Water cgreiner MKIII Supra 1 07-21-2009 03:49 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
