Old 02-24-2010, 06:52 PM   #1
OdysseusOnWheels
OdysseusOnWheels's Avatar
OdysseusOnWheels is on a distinguished road
Default 1986.5 Dashboard
I am going to restore a 1986.5 Toyota Supra, but I don't know what to do about the dashboard. The vinyl shrunk and cracked over the years that it has been sitting out in the sun. What is the best way to fix this? Applying new vinyl to the dash is an option, but I will need to know what type to use.
-OdysseusOnWheels
OdysseusOnWheels is offline   Reply With Quote
Old 02-24-2010, 07:51 PM   #2
OdysseusOnWheels
Did I post this in the wrong forum?
Old 02-24-2010, 11:27 PM   #3
Krem
pretty sure you're in the right section, but I've noticed a trend w/ this site is threads typically go unanswered until 1 or more replies appear on the topic list.. so maybe just my posting here will get you the attention you need.
However, as to your question, it's purely cosmetic and fairly easy to answer. Personally, I chose to go w/ a quick $25 "What you can't see won't make you look bad" solution by just throwing a dash cover up there... however, when I can afford it, I do intend to have the vinyl reupholstered... and if that's what you're looking to do, that's all you have to do... you wouldn't even take your car to a mechanic, but I'd probably feel better taking it to an auto paint, body & detailing company just to ensure it's done right. Professional upholsters might be able to do, but I'd imagine dash work is a bit different than fixing a couch, I'd prefer someone who's dealt with it time and time again rather than someone who makes an exception every now and then.
Old 02-25-2010, 02:58 AM   #4
OdysseusOnWheels
Thanks for the insight. I think I know someone who has dealt with this type of reupholstering.
Tags
dashboard, remodel
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
1986.5 Starting Problem supraman121 MKIII Supra 4 09-03-2006 03:51 AM
dashboard problems. anoboss Car Audio and Alarms 0 04-18-2006 01:36 PM
