Old 02-19-2010, 01:41 AM   #1
98poop
98poop is on a distinguished road
Default want motor
Wheres a good place to get a 2jz or 1jz at i need everything and what all cars do thoes motors come out of
98poop is offline   Reply With Quote
Old 02-19-2010, 11:27 PM   #2
supradaddy0803
supradaddy0803's Avatar
Well 1JZ and 2JZ's were in a lot of JDM cars. You got to make sure that it has a rear sump pan though or your gonna have to buy a oil pan and replace it. If you need everything like you say do a search online and look for JDM front clips. The clip is the car from the dash forward. Depending on your year model of car the clip is your best bet. Also don't forget if you are going from a W58 transmission to a 1JZ or a 2JZ your W58 drive shaft will not work. There are places to buy bell housings and adapters or you could just buy a R154 one piece drive shaft like I did. Do some searching around though. It is a decent swap for either engine and time consuming and expensive.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 02-22-2010, 04:39 AM   #3
suprabahamut
I bought my motor at Tiger Japanese it was clean and cheaper than other places. It came from Canada and the shipping was fast. As for the cars they sell the 7m engine from cressidas as well so some parts will have to changed like the oil pan. But for the 1jz and 2jz engines they have the cars they came out of listed when you click on them.
couple of questions about my 7MGE motor SDK MKIII Supra 2 12-13-2009 07:26 AM
Having trouble getting motor separated from tranny... shawn87gta MKIII Supra 15 05-08-2006 05:16 AM
7mge motor to 7mgte; no motor swap boogum7 MKIII Supra 9 12-10-2005 04:19 PM
