Old 02-04-2010, 03:32 AM   #1
If adjusting the spark advance is making a difference the physical timing is the most likely source of you headache. Pull the timing belt cover, reset the crank to 0 degrees, zero the cams back out, check the tension on the timing belt and pull the CPS/distributor and reset it to 0 degrees.
If you still have trouble check for error codes and post back.
And use more descript titles in the future...
MKIV Supra TT Daytime Running Lights?? MIX MKIV Supra 2 08-30-2007 02:52 AM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
Rough Idle????? ZauggIt1 MKIII Supra 2 11-11-2006 08:50 PM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
fixed the running rich problem djalkyd MKIII Supra 6 05-04-2006 04:31 AM
