Old 01-24-2010, 02:02 PM   #1
bryanf89
Default Water pump pulley
I just got a set of lightweight pullies for my 7m engine. It came with the alternator, crankshaft, and power steering pulley. Does anybody know if the sell a lightweight pulley for the water pump in a 7mgte engine?
Old 01-24-2010, 03:45 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
If your replacing a the crank pulley with a cheap ally one, you run the risk of damaging your engine. The heavy stock pulley is there for a reason, the weight of the pulley absorbs vibration from the crank. Links crankshaft torsional vibration. and resonance. If something rattles/vibrates place a heavy weight on the end of it.
Old 01-24-2010, 09:08 PM   #3
bryanf89
im not worried about that...do you know anybody that sells lightweight water pump pulleys?
Old 01-24-2010, 10:42 PM   #4
kamikazemkiii
kamikazemkiii is on a distinguished road
Ive heard because our cranks are so long, a lightweight crank pulley can accually break the crank
kamikazemkiii is offline   Reply With Quote
Old 01-24-2010, 10:47 PM   #5
bryanf89
ok this is about the water pump not the crank
Old 01-24-2010, 11:13 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Unorthodox Racing 4th one down in list.
Edit: Just noticed, it listed as for 2.5L 1JZ-GTE
Old 01-24-2010, 11:55 PM   #7
bryanf89
so no1 makes it for the 7m engine?
Old 01-25-2010, 07:59 AM   #8
two-step-n
dont buy crap obx racing crank pulley
Old 01-25-2010, 09:08 AM   #9
bryanf89
Default Uh-Oh!
I already purchased obx =| whats wrong with it?
Old 01-25-2010, 11:48 AM   #10
mirage83
On the crank pulley it does nothing to dampen/control vibrations. As Bill already mentioned, there's a reason the OEM units are heavy.
Tags
racing pullies, water pump
Power Steering Pump Pulley trevor217 MKIII Supra 4 05-17-2009 08:28 PM
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
Water Pump!!! IHateHacks MKIII Supra 10 05-16-2007 04:44 PM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
