Closed Thread
Old 01-23-2010, 04:18 AM   #21
Originally Posted by 98poop View Post
So i need to put a cooler thermastat in is that it cause thats the first thing im going to do is up the boost
I'm just going to get it out of the way now and save myself the typing later.... I'm sorry your car died.
cre is offline
Old 01-23-2010, 06:17 PM   #22
gteduck
gteduck is on a distinguished road
The engine i put in was a secondhand import. who knows how long it was sitting in a yard for, so the head had a heap of shit stuck in it somewhere. Witch finally came out after a year of giving it hell, on about 12pound boost. IT clogged the freshly cleaned radiator witch made it overheat BAD and it caused the factory HG to give up ever so slightly, it was blowing all the water out off the engine via reserve tank after hitting boost 1,2 or 3 times . it depended how hard i hit it. shift gears before boost and the water stayed where it should. Replaced HG with a cometic HG and ARP head studs. cleaned radiator out again ( take it to someone who will pull it apart and clean every little vein out with brushes properly ) AND DONT FORGET THE HEATER CORE TOO!!! i did and now i got shit in the radiator again and make sure the clutch on factory fan works properly .
gteduck is offline
Old 01-23-2010, 07:21 PM   #23
gteduck
when my 2nd hand import engine was first fitted we put boost up to 15 pound, boost peaked at 3500rpm making about195hp atw, power peaked at 234hp atw but boost dropped quite quickly down to about 10 pound boost at a tick over 5000rpm by then. IT had a slightly wilder tune by playing with cam timing via a vernier cam gear but it was a pig driving in traffic! . ABSOLUTELY NUTS ON OPEN ROAD THO, that made 274hp atw but also was losing boost due to only having 2.5 inch exhaust from firewall back. the timing change also let it rev out ALOT better. but all that being said, i was exspecting it to let go at any time. This engine and turbo were stock apart from EMS,boost controller. it also ran with custom exhaust and bigger fuel pump not factory. if u dont have funds to rebuild be very carefull what u do in your search for power. Compression might not be so good so you could blow out sump seal aswell, I DID !!!!!
FOCUS on Your cooling first, once it starts overheating it tends to have a snowball effect
gteduck is offline
Old 01-24-2010, 04:09 PM   #24
98poop
98poop is on a distinguished road
What degree thermastat shoul i put in it and wjere do i get it
98poop is offline
Old 01-24-2010, 04:55 PM   #25
gteduck
gte's run a 192 degrees F and ge's run 180 dedrees F ,you may aswell replace the heat sender unit to. both can be got at almost any auto parts store fairly cheap. get the 192 for turbo, sender units are the same for both models.
gteduck is offline
Old 01-24-2010, 10:28 PM   #26
98poop
This is probley a dumb question but whats the sending unit for and wheres it at
98poop is offline
Old 01-25-2010, 03:08 AM   #27
pretty sure you can find your answere here:
www.google.com
why are you hung up on this thermostat thing?
Green7mgte is offline
Old 01-25-2010, 03:29 AM   #28
gteduck
its the little thing that tells your temp gauge to go up and down, you know hot or cold.LOL
its in the bit you take off to get to the thermostat! now i suppose u want know which one it is.
gteduck is offline
Old 01-25-2010, 03:30 AM   #29
its the shiny metal thing that the big hose off the rad connects to
Old 01-25-2010, 03:37 AM   #30
gteduck
what's a rad? and where is it? lol
gteduck is offline
Closed Thread
