Closed Thread
Old 01-22-2010, 02:49 PM   #11
gteduck
gteduck is on a distinguished road
Default 7mgte mods
Originally Posted by 98poop View Post
i just bout a 87 supra and just wanted to know what r some good eazy mods to do to it. It is bone stock whit a new foctory turbo can u gus help me out
i dropped a 7 mgte in my mk2, up boost, via a turbosmart boost controller ,standard is about 5 to 6 pound boost. i went to 12 ~15 pound. Go 3'' exhaust all the way or bigger, depend on boost. I had 3'' of the turbo down to the floorpan ,then 2 and a half the rest but it got a bit restrictive at 15 pound. it would peak and then drop due to too much exhaust trying to get out the small pipe. 2.5 inch that is. a vernier timing gear on cam ( cheaper than new cam by far ) with intercooler . a good stock bottom end will be OK if comp is fine and motor aint clapped out (rooted that is ) no need to think about porting head. it will cost more than it will give you in return. keep an eye on fuel pressure to, if you dont go nuts it should be ok, but you cant go wrong with a walbro pump to be safe. mind you i'm running a microtech computer .
gteduck is offline
Old 01-22-2010, 03:27 PM   #12
BlckDragn
BlckDragn's Avatar
BlckDragn is on a distinguished road
where do you get the lexus MAF? what vehicle? year? and usually how much?
The Dragon
BlckDragn is offline
Old 01-22-2010, 04:40 PM   #13
87mk111
87mk111's Avatar
Lexus sc400, 92 to whenever they stopped making them. suprastore.com has the Maf and 550cc injectors, or you could look on ebay
87mk111 is offline
Old 01-22-2010, 05:10 PM   #14
BlckDragn
BlckDragn's Avatar
well thjank you very much indeed. and if you know.....my baby is spitting coolant out of the resiviorjust replace the water pump with a used one and a 160 thermo ran amazing for a few days and then started spittin again....
The Dragon
Old 01-22-2010, 08:51 PM   #15
Earlier xx400 series Lexus, not just the SC, and there was a change in the last couple years where something's different... I don't remember the details, I never went that route.
cre is offline
Old 01-22-2010, 08:55 PM   #16
Get the right thermostat in there, have the radiator cap tested and get the coolant tested... your HG may be leaking combustion gasses into the coolant system.
cre is offline
Old 01-23-2010, 12:12 AM   #17
98poop
98poop is on a distinguished road
Hard pipes cheap i want to run bout 15 psi does that car have possey or lsd if not can i weld the diff up when i go pick it up ill find out what problems it has
98poop is offline
Old 01-23-2010, 12:14 AM   #18
i would not run 15 psi less you get some major cooling into that engine!.
Green7mgte is offline
Old 01-23-2010, 02:10 AM   #19
98poop
So i need to put a cooler thermastat in is that it cause thats the first thing im going to do is up the boost
98poop is offline
Old 01-23-2010, 02:22 AM   #20
by all means up the boost. it will be no problem! the 7mgte engine is pretty durable. besides the HG low torque spec thing. just like most all turbo engines their built to be beat on. withstand higher pressure then N/a's ect.
but as im repeating. and i should of put this in my long post about BPU's (basic Performance upgrades) that anything above 14 psi will require internal work. but don't take my word for it do what you want. and yes i am airing on the side of caution but by all means pump it up to 15psi w/o forged internals or any sort of upgraded intercooler or radiator, oil cooler. see how long that lasts ya. now im not saying that YOU CANNOT! im just say that I WOULD NOT. but i could be wrong, I could be talking outa my hat. but am I?
i should mention that ive seen first hand what upping your boost too high on a stock engine WILL do.
I understand you wanna hop in and go fast. who dosent? but just because your car can go 55mph right after start up on a 25 degree morning dosen't mean you should. take my advice and get your cooling down atleast. before going over 15psi. get an intercooler i cant stress this enough on how much difference a new one vs a 20 year old one will have on your car.
i feel like im wasting my breath on this. good luck.
here just dont take my word for it
read this.
http://www.supramania.com/forums/showthread.php?t=82119
Closed Thread
