Old 12-12-2009, 03:06 PM   #1
bryanf89
Default throttle body question
i seen this throttle body on ebay and wanted to know what people think about it
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 12-12-2009, 07:50 PM   #2
Are you looking to use this on the stock manifold? Make sure you can find a TPS that can be wired to work with minimal effort too.
It's going to take some work to get it to mount to a stock 7M-GTE manifold. You should contact the seller and get the bolt pattern to make sure it's compatible with your manifold unless you're able to make an adapter plate or pay to have one built. It also will require some modification to get the throttle connected. The stock TB uses a linkage assembly to get around the fact that the cable comes from the intake side. With this you'll either need a long cable with a pretty heavy bend in it, OR you could go to a shorter cable and a custom bracket mounted to the intake side of the head.
Personally, I'd spend my money on other mods first, then worry about the TB. If the pulley was eccentric I would probably be interested though.
Old 12-12-2009, 08:02 PM   #3
bryanf89
what mods do you suggest?
Old 12-12-2009, 08:08 PM   #4
LOL! Ummm, what have you already done, what shape is the car in and what are your goals? I recommend supporting mods and repairs first... namely fuel system, brake and suspension.
Old 12-12-2009, 10:38 PM   #5
bryanf89
everything is stock i jus order a cold air intake kit thats about the only mod ive done to the car. the condition is GREAT except for this fender bender i had on fri =( damn taxi ram into my front end fender
its nothing to bad jus replace the fender but ill get everythin new since i went thru insurance
Old 12-21-2009, 01:11 AM   #6
StonecoreTx
StonecoreTx is on a distinguished road
call me crazy but that is a HUGE TB for a stock 7m build, especially if you have the factory 7m intake manifold.
86.5 mk3 supra 7mgte r154
StonecoreTx is offline   Reply With Quote
Old 12-21-2009, 02:00 AM   #7
bryanf89
Yes i deceided to wait till i modify the engine to get that TB
Old 12-21-2009, 03:13 AM   #8
Another question is... is the cold air intake really cold? Or did you just open up the intake to a whole lot of hot air with a nice big filter in the engine bay?
Old 12-21-2009, 03:25 AM   #9
bryanf89
Funny you should bring that up cre, i recently bought an apexi intake kit with an hps silicone turbo inlet. Once i get my exhaust system installed im going to wrap it up in insulation. I seen some1 take actual temps of the difference with exhaust insulation and engine bay was cooler by an average 100degress!!
Old 12-21-2009, 03:28 AM   #10
I've done actual tests and compared datalogs. If the filter is open to the engine bay, you're losing power... p e r i o d. You're better off with the stock airbox in that case.
Wide body kit question? JPDsupra MKIV Supra 1 04-22-2007 01:10 PM
Jdm Throttle Body Luvs2slide MKIII Supra 1 07-24-2006 07:15 AM
throttle body 87supraguy MKIII Supra 0 02-17-2006 02:40 AM
throttle body boogum7 MKIII Supra 5 12-21-2005 03:01 PM
