Old 12-07-2009, 05:16 AM   #1
Green7mgte
Supra Forum Moderator
Default coolant hose kit
any one know of a place to get a complete coolant hose kit besides http://www.hiperformancestore.com/toyota.htm
is $99 a good deal. wounder if i could find them any cheaper.
Old 12-07-2009, 06:38 AM   #2
Um... everything on that page is vacuum hoses... no coolant. Which is it you need? I don't know of any place that sells a full coolant hose kit.
If shopping for vacuum lines I'd price out buying the hose from siliconeintakes.com.... I've bought a lot from them in the past and they're very reputable, very high quality product and their prices are typically much better than most other places.
I've never heard of the shop you linked to... do some research to make sure they're OK before buying; There are shops that sell colored vinyl which is not acceptable.
If you are looking for vacuum hose here's a guide so you can be sure to order enough. http://www.cygnusx1.net/supra/TechTips/vacuum_hose.aspx The guide is for the GTE, so if your car is a GE you need to add 5 or 6 feet of 4mm hose. 4mm can be used in place of 3.5mm without issue. Place a small zip tie on the end of EVERY hose connection to help clamp and seal the line.
Old 12-07-2009, 08:06 PM   #3
Green7mgte
very informative thank you. the coolant hoses are as old as the car. and seem to be cracking one by one.. I replaced one just last week and now I need to do another so I figured I would knock them out all at the same time. I did a search for 7mgte Coolant hose kit and that's what popped up. one of the blue hoses in the picture is the one that I needed to replace. But thank you for taking a look. I guess I need to replace them one by one. to bad and yes I would not mind replacing my vac hoses also.
http://www.hiperformancestore.com/im...IIIturboUS.JPG
The larger blue one directly behind the fan. were my top rad hose connects into. (don't know the name of that)
Old 12-07-2009, 09:26 PM   #4
The coolant return from the turbo? The blue one which is connected to the top of the thermostat housing tower? I wouldn't use plain silicone hose there... you need something with a woven core on coolant lines.
Old 12-08-2009, 12:48 AM   #5
Green7mgte
yes indeed. coolant line ought not be replaced with cheaper versions..
Old 12-08-2009, 01:05 AM   #6
I mentioned that because it *looks* like regular silicone hose there and over at the throttle body's coolant lines.
Old 12-09-2009, 11:48 PM   #7
Green7mgte
I just went to AAP and bought some lengths of hose of different sizes so I don't have to dick around with this any longer. Ill eventually replace them all. I just wish someone offered a complete coolant hose replacement kit were I can get them all at the same time. Probably never gonna need to replace all your hoses at once but wtf why not.
Coolant Hose Diagram IHateHacks MKIII Supra 11 07-02-2013 03:08 AM
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Coolant Bypass Hose Routing corrosivecopper MKIII Supra 5 08-12-2009 05:16 PM
Replacing Clutch reservoir Hose and fixing rock plate (plastic one) Grandavi MKIII Supra 2 09-29-2008 04:49 AM
