Old 12-04-2009, 10:48 PM   #1
No, it won't damage the AFM (MAF is generally associated with a completely different type of air flow meter), but if the turbo flows much more air than stock you're going to hit fuel cut much sooner on the stock AFM and stock injectors... keep that in mind. If the turbo wasn't already used in a Supra you may also want to do the math and see if it's going to have a lot of lag or if it's going to choke on the top end.
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
