Old 01-21-2010, 06:33 AM   #1
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
Heh, for a while there I was thinking about parting it out for ya!
hahaha nice.
so tomorrow im going to try that out. im so shocked that the o-ring itself and the washer is enough to hold the gas. oh well. should be fine.
on a brighter side. ive been reading the "evosupra" new paint job thread........
some good entertainment.
cvbikeguy is offline   Reply With Quote
Old 01-21-2010, 07:01 AM   #2
Think about it, an even smaller O-Ring hold the fuel in the rail where the injectors connect... besides, I suspect the threads (when properly torqued) hold back most of the pressure. The FPR doesn't use a tapered thread (at least not from what I recall) so there's no worry about you having spread the opening too far... if it is tapered and the o-ring doesn't provide the seal, you may indeed be looking for a new fuel rail... But, I don't think that's the case at all.
Oh god... don't remind me... <----- All applicable.
Old 01-21-2010, 07:44 PM   #3
gteduck
gteduck is on a distinguished road
Default rebuild 7mge
so have you got it up and running yet? read the story!
it made me laugh and it made me cry!!!! i know exactly what you've gone through. i think i need to replace my 7mgte mk2 possible cracked block??? i dont want to look at it ,it might confirm my worst fears!!!!!!!!!
gteduck is offline   Reply With Quote
Old 01-22-2010, 02:20 AM   #4
cvbikeguy
cvbikeguy's Avatar
garr a leak so smallll. so the pressure regulator is still leaking. were gonna go with replacing it and also getting some new copper washers too. try again tomorrow after work.
Old 01-22-2010, 02:22 AM   #5
cvbikeguy
cvbikeguy's Avatar
did i mention the car sounds sooooo nice?
Old 01-22-2010, 03:48 AM   #6
cvbikeguy
cvbikeguy's Avatar
lol thanks so much. oh man cracked block. almsot thought i was going to have that. good luck!
Old 01-22-2010, 04:03 AM   #7
cvbikeguy
cvbikeguy's Avatar
ok so we tried again tonight. we bought a new o-ring but the gauge was thicker than the original so we tried the old o-ring again and of course it still leaked. and the the copper washers on the attaching union decided to leak. but thats an easy fix. could i possibly also be installing this wrong? do i take the o-ring off of the regulator and fit it in the space on the fuel rail before hand? and then once the ring is in i thread the regulator on? cause the fuel rail has a circular grove on the fuel rail around the threads where the regulator goes in. sorry i hope this is making sense. im kind of in a bind and im getting rides to work from family and im getting pressure to get a new FPR. i have a strong feeling im just missing something. can the nut on the FPR be in any position?
[/QUOTE]Oh god... don't remind me... <----- All applicable.[/QUOTE]
that was so ridiculous. people saying his car was actually cool and that nate shouldnt be hating.....
i almost had an asthma attack. my mom could tell that the car was crap and she started to laugh. i love this forum
wheres my inhaler...
Old 01-22-2010, 04:33 AM   #8
cvbikeguy
cvbikeguy's Avatar
trying to research
so ill try the new o-ring. but what does it mean loosen up the nut and turn the regulator counter clockwise.
this is embarrassing that im having so much trouble with this
Old 01-22-2010, 06:14 AM   #9
btwilson86
Super Moderator
btwilson86's Avatar
I think it means to loosen it so that you can rotate the pressure regulator independent of the lock nut position, allowing you to set it right and then torque the fpr down on the fuel rail.
Old 01-22-2010, 06:34 AM   #10
Wow.... umm.... yeah. I'm sorry you're having so much trouble too. I'll dig out my spare fuel rail and FPR and make a video this weekend if need be... you are making this too hard or something is F@$%ED up.
No, you can't install the O-ring before the FPR. A thicker O-ring could cause problems if it is too thick. Get the right size... it'll be metric. 10mmID x 2mm is what I come up with measuring mine and accounting for changes in shape from prior service.
Step one: With FPR off of fuel rail unthread lock nut all the way with just your fingers (this means the lock nut will move UP toward the FPR's body).
Step two: screw FPR onto the fuel rail by hand until it stops... DO NOT TIGHTEN ANYTHING!
Step three: Unscrew the FPR just enough to get it pointing the right direction.
Step four: tighten lock nut.
NOTE: To help ensure that the o-ring isn't getting pinched you may wet it with a little soapy water before threading the FPR onto the rail.
Lower Ball Joints - Checking here first Grandavi MKIII Supra 3 09-20-2008 04:04 AM
Picking up my 89 tomorrow 8uwav6 Show n Tell 2 03-31-2008 08:08 PM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Supra Noob checking in from Florida PalmCoastMk3 Non-Generation Specific Questions 1 12-23-2005 05:08 PM
Supra Newb Just checking in Razor Non-Generation Specific Questions 1 12-21-2005 04:15 AM
