Old 08-15-2005, 06:35 AM   #1
huggybear16
huggybear16 is on a distinguished road
I have a 1988 supra n/a automatic, It is my project car, I am wanting to know how much it whould cost total for the 1jz-gte swap, and will it drop right in?? what will I have to mod in order to get it to fit?? also how much whould it cost to put a manual in with it?? thanks
huggybear16 is offline   Reply With Quote
Old 08-15-2005, 10:06 AM   #2
you will either need the 89+ crossmember or the custom mounts (i will find link later) that will bolt to your crossmember
price wise i'm not sure.... usa guys... help us out here
Old 08-15-2005, 03:54 PM   #3
Troyota
Troyota is on a distinguished road
You will need either a late 89 or newer front cross member or these mounts:
1jz mounts
You'll need the power steering lines from an MKIV as well as the throttle cable from the MKIV. If you want the A/C to work, you need the compressor head from your 7M. The wiring is the biggest issue, you need to extend the wiring harness a couple feet (I've heard as little as 18") and I'm not sure, but I don't know if the NA tach will work with the JZ computer...I have yet to get an answer on this one.
In order to do the 5 speed swap, it'd be best to have a front clip w/ a 5speed in it just to have a donor for all the components like master cylinder and all that jazz...otherwise, the 5 speed stuff from a USDM 7M supra will work...you have to have the R154 trans...but the 1JZ bellhousing is a must. A friend who did another JDM swap (All-trac 3SGTE into NA Auto Celica) said you need the pedals from a USDM car too, because they are different in the JDM car...I don't know if this is applicable to the 1JZ swap, but I wouldn't take any chances. Then bet on a few other misc expenses...I wouldn't jump into this project w/o at least $5,000 alocated to it....you may come in less, maybe way less...but I'd expect the worst and hope for the best.
1987 N/A MA70 Supra <--1JZ swap in progress
1986 AE86 GT-S Hatchback
2002 DC5 RSX Type S
Troyota is offline   Reply With Quote
Old 08-15-2005, 07:41 PM   #4
huggybear16
1jz mounts
thanks yall, I belive i might just put a 7mgte in it, what all do you have to mod to drop it in, also yall have any links for front clip sales??
Old 08-16-2005, 06:47 AM   #5
Troyota
Tell ya what...when I first got my Supra, this was the swap I was gonna do. Much cheaper...straight forward and still a good way to go...most people who own MKIII's will honestly never really think seriously of undertaking a 1JZ swap. Unfortunately I don't have any real information on this swap, however, I do know of at least two people who have done it in my town...I suggest Google or even try forums like this...I bet someone will chime in here any day and post up the details on a 7MGTE swap or at least point you in the right direction. But glad I could at least put the 1JZ swap in perspective for you. And just ask suprra_girl the 7M is a very capable platform.
2002 DC5 RSX Type S
Old 08-16-2005, 07:14 AM   #6
SupraMan1784
well...i could get a 1jz motor for about 1900 which is pretty good, the rest is just gonna be labor...i say about 3500-4500 depending on how much u get the motor for and then how much labor cost is for the installation unless you are doing it yourself
Now: Saving for an MKIV
Broken Rides:
Old 08-17-2005, 07:18 AM   #7
daiagaru2
daiagaru2 is on a distinguished road
your n/a tach will not work with the 1jz-gte harness,get an aftermarket one from pivot,these wire into the 1jz nicely.
daiagaru2 is offline   Reply With Quote
Old 08-22-2005, 06:12 AM   #8
Supra Guest92supra
Guest
Posts: n/a
Hey guys if you need help with the 1jz swap go to my site for any help. It has all the info on what you need to do and everything.
1jz swap
Any questions just email me and i'll be happy to try and help if i can. At the moment i am trying to get mine running as you can see on the site.
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
to swap or not to swap edelmar417 MKII Supra 16 04-10-2007 12:06 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
