Old 10-16-2009, 05:11 PM   #1
Cyto
Cyto's Avatar
Cyto is on a distinguished road
Exclamation Mystery Wire?
Okay, well after I got curious about my engine light for the first time in 7 months, I looked around on the forums and found something about a spade connector under the inlet manifold. I have no idea what an inlet manifold, so I just went and looked around. Needless to say the first wire I checked was disconnected. So I need somebody to help me figure out where this thing goes...lol I can't find anything.
Here are the pics.
If anybody has any suggestions I would be very happy
Proud owner of a 1988 Toyota Supra Turbo, 105k Miles, and great condition.
I might have to sell it to help pay for school so here's the link.
http://www.toyota-supra.info/forums/...html#post72357
Cyto is offline   Reply With Quote
Old 10-16-2009, 06:14 PM   #2
Krem
Went out and looked at mine... it's plugged into a circular plate lookin thing, similar to a horn or even that pressure regulator in the pictures you showed. If it helps, it's located between my power steering and the left hood strut... and it's the only thing between the two...
Old 10-17-2009, 06:22 PM   #3
Cyto
Cyto's Avatar
I still can't find a plug hole lol
Old 10-18-2009, 07:09 AM   #4
It connects to the factory alarm's horn which is mounted to the firewall next to the brake booster. I can't see enough in your picture to see where it mounts, but if you're not seeing the other end I presume the horn has been removed entirely.
http://www.cygnusx1.net/Supra/Librar...spx?F=8611&P=1
Old 10-19-2009, 12:58 AM   #5
Krem
Heh, no wonder it looks like a horn... but wait... there's a factory alarm on the car? how come mine never goes off... nor do I have a remote to arm it...
Old 10-19-2009, 04:10 AM   #6
It didn't come with a remote... not a keyless system. It comes on automatically after the last door is closed when the doors are locked. There is a sensor in each of the three lock cylinders to arm and disarm it. in '91 and '92 the system was built a little differently and a keyless module was offered by Toyota which just plugged right in.
If you don't see the light on the dash labeled "Security" light up then the alarm is not arming... this is due to one of three things usually: bad lock sensor, bad trigger sensor (doors, hood and hatch) or it's been disabled on purpose.
Old 10-19-2009, 06:21 PM   #7
Krem
Dang... looks like I'm insecure...
where and wha color is the speed sensor and rpm signal wire 88Tsupra MKIII Supra 6 03-16-2011 07:48 PM
foglight anyone kelloggs067 MKIII Supra 1 10-06-2009 02:08 PM
Question on wire for rewiring KS redmaro MKIII Supra 8 09-30-2007 04:11 AM
Small Fan with Split wire scruffboy Non-Generation Specific Questions 0 12-04-2006 02:32 PM
need help: wire coming off A/C compressor - to? theWeezL MKIII Supra 5 05-17-2006 11:26 PM
