Old 10-13-2009, 04:15 PM   #9
2jzmaestro
2jzmaestro is on a distinguished road
I believe after changing your brake lines and your brake fluid, your cars braking system is gonna feel much better. I hope this helps. The rust on the inside of the rotors (not the surface that touches the pad) is normal. As long as the surface that touches the pad is in good condition everything should be gravy.
Hope it heps
2jzmaestro is offline   Reply With Quote
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
