Old 10-19-2009, 05:05 AM   #10
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by 2jzmaestro View Post
I believe after changing your brake lines and your brake fluid, your cars braking system is gonna feel much better. I hope this helps. The rust on the inside of the rotors (not the surface that touches the pad) is normal. As long as the surface that touches the pad is in good condition everything should be gravy.
Hope it heps
Thanks, I know you can't see it but the pads in the posting have rust spread lightly across the pad on the side that touches the rotor. That's why I changed them out to some new ones. I ordered my new brake lines still waiting for them to get here. Next time I'm going to upgrade my rotors. By the way does any one know a good website where I can purchase performance calipers? I just want the calipers and not the whole kit. Thanks.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
