Old 10-02-2009, 06:02 AM   #11
Well, water pump's are wear items, so IMO it's always good to replace it. I should change mine out, actually...
Swollen hoses also interfere with the cooling system purge, as it expands and contracts with pressure/vacuum.
Let us know what happens with the new parts
Old 10-02-2009, 06:50 AM   #12
Tbredd7
Tbredd7 is on a distinguished road
when I drive sometimes not all the time it will start hesitating while the accelarator is pressed
I am experiencing the exact same problem with the 86.5 7mge I just purchased. If you fix the problem please let me know what you did. I am going to start by replacing some vacuum lines.
Tbredd7 is offline   Reply With Quote
Old 10-02-2009, 07:31 AM   #13
86.5 7MGE
86.5 7MGE's Avatar
Good luck to you too, and if you figure it out before I do let me know as well...thanx
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 10-03-2009, 11:45 PM   #14
86.5 7MGE
86.5 7MGE's Avatar
Right as it sttarts to hesitate I start to smell a strong odor of gasoline I just recently started running 91 grade was running 89 grade or mid grade. I'm starting to think it may be the timing or bad injectors...maybe even both.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-04-2009, 12:06 AM   #15
Krem
eh? upgrading the fuel could cause problems? I thought it was if you downgraded the fuel, you were more susceptible to problems?
Old 10-04-2009, 02:57 AM   #16
86.5 7MGE
86.5 7MGE's Avatar
No, I still have the stock fuel system set up for the N/A. I want to upgrade my system eventually when I get to that stage. But, I was saying that since my injectors are so old they are probably wearing or worn out already thus causing hesitation at times. Or my timing could be off and causing the problem too I have to look into that after fixing my current problems.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-07-2009, 04:42 PM   #17
oregonjoe
oregonjoe's Avatar
Default Bhg?
Check your plugs - if they look like coolant or have deposits its a BHG - Start with NO 6 as that is the most common - All plugs should be dry and light tan. Mine ran rough after sitting overnight and was burning coolant same on acceleration
Old 10-12-2009, 02:45 PM   #18
AAPSuprabuilder
AAPSuprabuilder is on a distinguished road
Smile
I just got done with that same issue on my 87, I replaced the head gasket had all new hoses installed, put a new water pump on and fan clutch. All to find out my radiator wasn't cooling to specification so when the car stopped the pressure was still in the system as the coolant was too hot. I HIGHLY recommend taking out the radiator, take it to a radiator shop and have them flow test it. The average cost is around $15.00. It may save you hundreds in the long run and either way you know for certain if it is or isn't good enough at cooling. As the radiator heats up the fins are supposed to disperse the heat although a Toyota that is older sometimes has their radiators deteriorate. the money you spend on getting it tested will easily pay for your time and frustration in the long run.
AAPSuprabuilder is offline   Reply With Quote
Old 10-13-2009, 04:04 AM   #19
86.5 7MGE
86.5 7MGE's Avatar
Thanks for the input I'll look into that, I was wanting to get an aluminum radiator any ways now I might have a reason to get it earlier than anticipated
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 10-13-2009, 05:08 AM   #20
86.5 7MGE
86.5 7MGE's Avatar
Alright, so I finally changed out my water pump and two more short hoses that had a crack in them and were swollen. I noticed that there is some pitting or scraping inside the chamber where the water pump sat, hopefully it's nothing to be concerned about. The water pump didn't didn't look too bad, but I changed it out anyways to keep from doing it later on down the road. In the process of it all I ended up with a broken temp fuel control sensor I think that's what it's called and now have to wait until Thursday or Friday for the part to come in from Toyota. So, now I won't be able to test out my work until then. But on the positive side it forces me to wait to make sure I have a good seal formed before I put antifreeze in and start putting pressure back on the system, should be good since I used high temp RTV in place of the gasket cause the gasket it came with was destroyed to begin with.
ID:	2429   Click image for larger version
ID:	2430   Click image for larger version
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
7MGE ECU problems grabber MKIII Supra 2 06-10-2009 10:53 PM
86.5 7MGE supra smog test fails googoogaga Non-Generation Specific Questions 7 10-18-2006 02:44 AM
fuel problems in 86.5 86.5mkiii MKIII Supra 3 09-18-2006 10:00 PM
