Old 08-05-2005, 01:25 PM   #1
bigal0043
bigal0043's Avatar
bigal0043 is on a distinguished road
I was thinking around 300whp?
Alright what kinda whp numbers should i expect to get in a
1987 supra turbo 7mgte
mods include
metal head gasket
ARP Studs
boost controller set to around 9 psi
K+N air filter
New 3inch elbow
what kinda numbers do u get when u add in complete 3 inch exhaust?
bigal0043 is offline   Reply With Quote
Old 08-05-2005, 01:42 PM   #2
ddmcse
ddmcse's Avatar
spend 60 bucks and get it to a dyno .
it's a good idea to get some kind of baseline .
i got a big lift from the 3 " cat back (no cat) prolly around 35 hp .. adding 3" elbow and 3" no pre-cat downpipe was "more" icing on the cake .
using :
elect fan
no a/c
no cat
frees a little more juice
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-05-2005, 01:55 PM   #3
bigal0043
bigal0043's Avatar
yea the closest dyno is like 2 and half hours away so i was just curious on what other people were putting down when they had those mods
Old 08-05-2005, 02:12 PM   #4
daiagaru2
daiagaru2 is on a distinguished road
with those mods and a couple pounds more boost you will be very close to the ball park,of course if you remove the cat(s) then it is an off road vehicle,include a 3" down pipe and your really close.of course altitude and weather conditions durring testing will affect your power #.
daiagaru2 is offline   Reply With Quote
Old 08-05-2005, 02:19 PM   #5
bigal0043
bigal0043's Avatar
At 9 psi i shouldnt hit fuel cut off should i?
ive heard u can go to 10psi but may hit fuel cut off now and then
Thanks for ur reply
Old 08-05-2005, 02:38 PM   #6
ddmcse
ddmcse's Avatar
fco depends on a lot of factors .including outside temp and humidity
exact fco today is going to be different tonight and tomorrow
for example if are set to boost 9 lbs and are missing fco in the afternoon the next morning when you go for that first boost everything is cool and you'll get more air which will prolly hit fco one time that first time .
My Supra KiXGaS
Old 08-05-2005, 03:02 PM   #7
bigal0043
bigal0043's Avatar
alright ill keep that in mind then....
to raise the fuel cut off i need a lexus afm right??
i know i need 550cc injectors and a upgraded fuel pump
i was looking at this on ebay... is this a fake??
http://cgi.ebay.com/ebaymotors/LEXUS-AFM-S...sspagenameZWDVW
also found this link
http://cgi.ebay.com/ebaymotors/LEXUS-1UZFE...sspagenameZWDVW
Old 08-06-2005, 04:20 AM   #8
daiagaru2
get a fuel cut defencer from hks,this should solve the problem.
Old 08-06-2005, 05:45 AM   #9
Poodles
Poodles is on a distinguished road
Yes, using the lexus AFM with larger injectors is a great upgrade. It's not only to up fule cut, but to keep on the safe side of flowing enough fuel to keep you from going lean. Do NOT install just the AFM, you need to do the AFM and injectors at the same time unless you want to throw your ratio so far out of whack you'll run either really rich, or so lean you break something...
Elbow's are good addons for the engines. Seing the dyno sheets is pretty scary about waht just a down tube and exhaust will do... personally I want a divorced down pipe which vents excess boost from the wastegate out a seperate path instead of interupting exhaust flow.
Poodles is offline   Reply With Quote
Old 08-06-2005, 11:08 AM   #10
ddmcse
ddmcse's Avatar
i haven't seen anyone mention the custom air screw needed for the lexus air flow meter
i am having one made
My Supra KiXGaS
Got oil on top of your spark plugs?? IHateHacks MKIII FAQ 20 06-04-2013 01:48 AM
my new supra more power... MKIV Supra 29 09-11-2007 05:33 PM
fuel pump hanger part numbers rlipp69 Non-Generation Specific Questions 0 06-18-2007 03:23 AM
what are factory compression test numbers? 2JZEFINI-17 MKIII Supra 1 11-05-2006 11:58 PM
