Old 07-15-2009, 10:27 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
It’s not possible to see the cam belt tensioner unless you remove the cam belt cover. There is an oil feed and oil return pipe for the turbo on that side of the engine block (7M-GTE) as well as the oil pressure sensor and dip stick hole. Cam covers often leak, but the oil normally runs to the back of the engine due to the engine slightly tilted back at an angle. You’re best bet is to clean as much as the oil up and try to locate the general location of the leak. Its also possible the oil is leaking from the cam seals and dripping down behind the cam covers. It is engine oil and not power steering fluid ?
Oil Leak. supramacist MKIII Supra 0 05-01-2008 01:18 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
